Suspension When I Sheft My Gear To The Reverse...
Old Oct 31, 2006 | 02:39 AM
harhoosh's Avatar
harhoosh
Mini Cooper JCW Model 03
When I Sheft My Gear To The Reverse there is sound from front wheels
even if i drive slowly i hear Clicking Noise
Hope Its not a Major Problem ..
Dose Anyone face this problem ??
Old Oct 31, 2006 | 03:54 AM
satay-ayam's Avatar
satay-ayam
clicking is normally a sympton of a bad CV joint.
Old Oct 31, 2006 | 04:23 AM
harhoosh's Avatar
harhoosh
Its not normal .. becouse my frd has mini cooper, i cant heat this noise from it :S
Old Oct 31, 2006 | 05:07 AM
kenchan's Avatar
kenchan
there should be no clicking
Old Oct 31, 2006 | 05:12 AM
satay-ayam's Avatar
satay-ayam
Maybe you misread my post ... I wasn't saying that "clicking is normal", I was saying that clicking is normally (ie typically or often or commonly) a symptom of a *bad* CV joint.
Edit, so in other words, "check your CV joints".
Old Oct 31, 2006 | 05:00 PM
Bilbo-Baggins's Avatar
Bilbo-Baggins
Is the clicking you hear speed related? ie: faster click rate the faster the car is moving
Clicking could also be a problem with a wheel. Not torqued properly, or a crack in a wheel.
CV joint noise is usually heard when the steering wheel is turned to near full lock.
Old Oct 31, 2006 | 08:42 PM
harhoosh's Avatar
harhoosh
When i hit a bump i hear a squeak from the front of the car Only
Even if i drive fast :S
Is it a Major problem :S because im dealing only with the dealer, and they are charging us too MUCH
MINI Stupor
Oct 1, 2015 11:36 AM
gknorr
Oct 1, 2015 09:20 AM
patsum
Sep 30, 2015 02:10 PM
bahman
Sep 30, 2015 01:59 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
