R50/53 Does faceplate come off?
Old Oct 26, 2006 | 01:22 PM
zeusboy's Avatar
zeusboy
I was just wondering if anybody knew if the faceplate to the speedometer (traditional center) comes off. I'm getting dust behind the faceplate and also behind the faceplate to the auto climate control. Not sure how it's happening.
I know many instructions to the MINI are "it just pops off", but I thought I'd ask before I tried something like that.
Any help would be greatly appreciated.
Old Oct 27, 2006 | 06:39 AM
zeusboy's Avatar
zeusboy
Bump. Anybody?
Old Oct 27, 2006 | 06:46 AM
rivet's Avatar
rivet
I am sure they come off. Other people are replacing the speedo dial graphic. Search some of the forms and you should find an answer.
Old Oct 27, 2006 | 07:42 AM
Kentiki's Avatar
Kentiki
It does come off. I removed a couple screws under the trim in the speedo area (sorry for lack of detail here). Then the plastic dash trim pops off with a bit of a fight. Then the entire speedo unit has 4 screws holding it on. Once you remove those, the entire unit comes out, and you can unclip it from the wiring harness. I seem to remember the clear plastic cover falls off at this point pretty much by itself!
c0op3r
Feb 25, 2014 09:40 PM
astroBlackMetallic_Mini
Jun 20, 2012 12:40 PM
markldriskill
May 14, 2007 11:30 AM
