Drivetrain Improved belt tensioner
Old Oct 26, 2006 | 11:11 AM
S_Hapens's Avatar
S_Hapens
I am currently running the 19% pulley and am on my 3rd belt. Each time the belt breaks the belt tensioner slams into the crank pulley...destroying it (3rd crank pulley too). I am going to install the mymini tensioner limit stop tomorrow as well as a new belt tensioner assembly but I was wondering if anyone has seen any product to replace this poorly designed belt tensioner. If you have seen Ryephile's belt tensioner on his turbo only setup this is kinda what I am looking for.
Old Oct 26, 2006 | 12:20 PM
obehave's Avatar
obehave
GT Tuning has a nice one
Old Oct 26, 2006 | 12:35 PM
SumWon's Avatar
SumWon
I have the GT Tunning Tensioner limit stop:
Which is very similar to the MyMINI stop. I have lost one belt while driving and the limit did its job. I had belt all over the engine bay, but the tensioner pulley did not crash the crank pulley.
I highly recomment it!
Old Oct 26, 2006 | 12:41 PM
MSFITOY's Avatar
MSFITOY
Mine's from Myminiparts and it looks exactly like this one...guess the "patent pending" doesn't apply to over seas...
Which is very similar to the MyMINI stop. I have losted one belt while driving and the limit did its job. I had belt all over the engine bay, but the tensioner pulley did not crash the crank pulley.
Old Oct 26, 2006 | 02:26 PM
S_Hapens's Avatar
S_Hapens
cool the mymini version is going on tomorrow and i wont be scared to visit red line anymore, a broken belt i can deal with but replacing the crank every time is a b!tch
Old Oct 27, 2006 | 11:10 PM
jimz68's Avatar
jimz68
Hmm. That stop plate looks like a good idea.
Does the tensioner assembly have a "service life"? ie, should it be replaced at X amount of miles? I ask because I have about 93k miles on the car,60k with the 15% and 45k or so with the 15% and the 2% crank. I'd hate to sieze the tensioner pulley!
Thanks!
Jim
Old Oct 28, 2006 | 06:29 PM
Johan's Avatar
Johan
Thanks!
Jim
In all honesty I doubt it. What's the life of a belt, 20,000 miles? I would recomend chaning your belt if you haven't yet. Even if it looks good...they're cheap enough and worth the comfort of knowing. I've been changing mine less then every 10,000 -- Johan
Old Oct 28, 2006 | 06:35 PM
Longboard110's Avatar
Longboard110
did you buy one of those belt tensioner tools or did you fab your own?
Old Oct 28, 2006 | 06:56 PM
MSFITOY's Avatar
MSFITOY
I decided on a belt change through DT along with the tensioner replacement at around 54,000 miles (first was around 25k but this was still way late!)...when Chad removed the tensioner, it was nearly shot and started to chew my belt and pullies
Two weeks later, one of our members with fewer miles snapped his belt while we were at MIS...he got two laps in and was flat bedded home
Check your belt and tensioners ladies...flat beds are expensive
Old Oct 28, 2006 | 06:59 PM
Johan's Avatar
Johan
Actually I've been using someone elses. There easy enough to fab on your own and cheap enough to buy.
Old Oct 28, 2006 | 07:27 PM
indygomini's Avatar
indygomini
Now you've all gone and made me (more) paranoid. Since I have a new belt waiting to be installed, I ordered a stop bar- better safe than sorry.
No sense keeping the belt tensioner tool and a spare belt in the boot for roadside repairs, if a broken belt means a trashed crank pulley!
Old Oct 28, 2006 | 07:36 PM
Motor On's Avatar
Motor On
I thought factory belt was supposed to be able to make it 60k.
Old Oct 28, 2006 | 07:39 PM
MSFITOY's Avatar
MSFITOY
With my Mom driving...
Old Oct 28, 2006 | 07:43 PM
Motor On's Avatar
Motor On
I can pounce on it at 42.7k without issue. (better go check mine though) I've heard several mention MINI claims for them to be able to last in the 50k-60k mile mark.
Old Oct 28, 2006 | 07:53 PM
jimz68's Avatar
jimz68
Yes I have changed the belt twice. Think I'll order a stop bar and a new tensioner, too.
Thanks All!!
Jim
Old Oct 28, 2006 | 08:08 PM
MSFITOY's Avatar
MSFITOY
I know I know...I was surprised my tensioner was going south...it's cheap insurance to check/replace these parts...belt or tensioner goes, no alternator, no water pump, walk...sucks flat bedding miles away from home...
Old Oct 28, 2006 | 08:09 PM
Bilbo-Baggins's Avatar
Bilbo-Baggins
Definitely sounds like a good idea to check regularly and have the stop bar installed. Better safe than sorry.
Adds another item to his "to do" list.
Old Oct 28, 2006 | 08:36 PM
herbie hind's Avatar
herbie hind
can you imagine what the regular *** paysto have this stuff done perodically at what 100.00 an hr?!!!wow!!impatient:impatient
Old Oct 30, 2006 | 12:17 PM
TampaMCS's Avatar
TampaMCS
Has anyone actually installed this? Photos / directions?
Old Oct 30, 2006 | 12:27 PM
MSFITOY's Avatar
MSFITOY
Post #4...
Old Oct 30, 2006 | 12:29 PM
Partsman's Avatar
Partsman
Legion_of_Doom
I must have installed/uninstalled this thing a million times. I eventually just threaded a bolt in from the backside where the slotted end of the stop will go, and used a lock nut.
Park the car with wheels cranked to the right
Remove the four plastic expanding rivets in the fender liner, three in front, one on the inside
Remove the philips head screw directly above the tire, use a stubby screwdiver
Remove the philips head screw that holds the front of the fender liner, it's a little to the right of the fog lamp area, under the bumper cover, use the stubby here too
Gently pull the fender liner away from the body and around the sensor wire
You should be able to see and access the front bolt for the tensioner "shock" the rear one can be reached from behind the engine.
Old Oct 30, 2006 | 12:32 PM
tnoy66's Avatar
tnoy66
I've got the GTT Tensioner Pulley and Limit Stop among other bits of his
Though I've no directions or pics of how to do it, I just paid the man himself to fit it all then drove away rather quicker than I arrived
Old Oct 31, 2006 | 04:53 AM
SumWon's Avatar
SumWon
That's my tensioner in #3. I put mine on while I was replacing the crank pulley. It is not required to remove the tensioner to put the limit stop on, but I also added the GT Tuning tensioner and idler pulleys at the same time. I figured while I had it apart, might as well get it all done.
Old Oct 31, 2006 | 08:34 AM
TampaMCS's Avatar
TampaMCS
So I do not need to release the tension to do it? Just do one side at a time?
Old Oct 31, 2006 | 08:37 AM
Partsman's Avatar
Partsman
Legion_of_Doom
It can be done without releasing the tension, it's a little easier to do one bolt at time.
