Suspension wheels - 16 vs 17
Old Oct 24, 2006 | 12:02 PM
DoneDirtCheap's Avatar
DoneDirtCheap
wheels - 16 vs 17
Hello all,
I figured I may as well make my first post interesting. I'm looking for information on pros & cons of 16 vs 17 inch wheels for an S. I plan on adding coil-overs for track days in the near future. Here's what I can think of so far
17
Pros fits bigger brakes
Old Oct 24, 2006 | 12:06 PM
obehave's Avatar
obehave
17" Cons - weight & expense
17" Pros - Usually better tire selection
Old Oct 24, 2006 | 12:18 PM
DoneDirtCheap
Ok.. noob (me) hit enter too fast and inadvertently posted.... I'm sure that happens to every guy.... BUT.. that makes this post #2!
what I meant to finish:
I'm looking for input on pros & cons of 16 vs 17 inch wheels for an S. I plan on adding coil-overs and camber plates&arms for track days in the very near future (as well as a bbk.) Here's what I can think of so far (and btw, I'm still running s-lites now....)
17
Pros - fits bigger brakes
Cons - Heavier than 16s
16
Pros - lighter than 17s
Cons - smaller brake rotors req'd (12.2" Wilwood max??)
too low with coilovers and 45 or 40 profile tires?
TIA -
Tom
2006 MCS (I'll get to a real sig one of these days....)
Old Oct 24, 2006 | 12:27 PM
Mini Mizer's Avatar
Mini Mizer
Here is a previous post about 16 vs. 17
https://www.northamericanmotoring.co...t=QUARTER+DIME
read post #6
As far as brakes go, i would leave them stock diameter, and upgrade rotors/pads/brake fluid.
cheaper, easier to do and will provide enough performance.
Old Oct 24, 2006 | 01:01 PM
DoneDirtCheap
Thanks mini mizer... great explanation in the reference.
Interesting reading.....
Old Oct 24, 2006 | 01:12 PM
meb's Avatar
meb
You have to research wheel weights, not all 17s are heavier than 16s.
Ideally, wheel size (dia.) should be determined by braking needs. Width and offset are considerations too, but for different reasons - width will affect weight to. And, forged or not forged $$$$$ or not
My 17"x7" BBS RGRs weigh 16.1 pounds and are forged and cost if I remember, $600..00 each new. My 17x7 Team Dynamic Pro Race 1s weigh 16.1 pounds also, but are not forged and cost $175.00 each new. Strength is another consideration...
Stick with an offset around 38-40mm.
Old Oct 24, 2006 | 01:39 PM
kenchan's Avatar
kenchan
^^ both your 17's are heavier than my 16x7.5 SSR comps (11.5lbs each), doc.
Old Oct 24, 2006 | 02:34 PM
DoneDirtCheap
Agreed. I'm considering the SSR Type C (17x7.5 = 13.7 lbs 16x7 = 11 lbs) and the Motegi Traclite(17" 15 lbs.)
I started looking at tire reviews and low and behold, that's where so many 16 v 17 threads are... wheels under wheels. Guess I was in suspension mode....
Thanks for the help. I'm looking forward to getting more goodies for the car and providing some valuable input on the forum.
Old Oct 24, 2006 | 03:16 PM
obehave's Avatar
obehave
Yes but.... the lightest 16 is lighter than the lightest 17
And yes no one mentioned the width factor.
Of course tire choice should be a major factor in this. So you save a few lbs in wheel weight and then lose it by going with heavy tires.
Which leads to...
17"
If you want major footprint there's more choices with 17s
16x8s are hard to come by. 17x8 not so, for example.
16" Pro
Generally speaking(that's for you meb ) better ride quality.
barnoun
Sep 17, 2018 05:04 PM
khumpert
Nov 30, 2015 11:48 AM
SosoMINI
Nov 22, 2015 03:17 PM
Tires, Wheels & Brakes
Aug 26, 2015 11:02 AM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
