Advice on new Rotors
Old Oct 22, 2006 | 04:44 PM
RoadFly's Avatar
RoadFly
I have the JCW brakes but was thinking about some cross-drilled / slotted rotors. Any advice on which brand to look into? Any photos of brakes welcome for an idea of how they look on your MINI's. Thanks
Old Oct 22, 2006 | 11:06 PM
YakiMini's Avatar
YakiMini
The president of www.psmini.org (my club) has this set and suggested that I add them since I was looking to replace my OEM rotors earlier this year. It was the best deal $$$$ with out going to brake kit from what little I know.
http://cgi.ebay.com/ebaymotors/Mini-...spagenameZWDVW
Old Oct 22, 2006 | 11:10 PM
cooper99's Avatar
cooper99
I don't believe those rotors from ebay will fit your aftermarket JCW brake kit; doesn't the JCW kit have larger rotors?
Old Oct 22, 2006 | 11:14 PM
YakiMini's Avatar
YakiMini
Once again, you could be right on this one :-) I'm not certain of the differences. Roadfly, you could find out the dimentions and then ask vendors if they have a match?
Old Oct 23, 2006 | 04:52 AM
jonnieoh's Avatar
jonnieoh
I've researched getting a big brake kit for months now, and on all the posts I've read, the vast majority of posters recommend NOT getting cross-drilled rotors, because they will crack between the holes, radiating from the center out to the edge.
You will see this illustrated plenty here on NAM, if you just look for it.
I haven't pulled the trigger yet, but when I do, I was planning on going with slotted, (if anything other than just a plain rotor)...
Old Oct 23, 2006 | 04:27 PM
RoadFly's Avatar
RoadFly
Thanks jonnieoh -- thats good to know cross-drilled OUT - slotted In -- YakiMini -- I will have to do that thanks...
Old Oct 24, 2006 | 08:23 AM
limster's Avatar
limster
Roadfly,
I think you have to ask yourself what you want out of the brakes. Are you going to autocross, are you a aggresive street driver? I belong to a M3 forum and a lot of those guys track their cars and outside of those guys that do a lot of hardcore racing, most advise against cross drilled and slotted rotors. You might be better off with a good set of brake pads (Hawk, Axxis etc.), high quality brake fluid, and lastly and most important a good set of tires. IMHO cross drilled and slotted rotors are more for bling than for performance. That being said, they do look very cool.
My 2cents
Old Oct 24, 2006 | 10:26 AM
BradB's Avatar
BradB
Yep, it's happened to me. Get slotted, not drilled. The best I have used to date are PowerSlot Cryo rotors. They don't have as much tendency to warp, either.
Old Oct 24, 2006 | 03:56 PM
RoadFly's Avatar
RoadFly
I guess my track days will be once every 3 months or so, and street is kept to a min. at most, so I guess the bling is my ego screeming at me to look good behind my shoes. LOL thanks for the ego check...
Old Oct 24, 2006 | 04:02 PM
DrkSilvrMini's Avatar
DrkSilvrMini
Slotted rotors are gonna be your best bet.
dont get the cross drilled because they tend to crack under high heat.
Old Oct 24, 2006 | 04:22 PM
Mini Works's Avatar
Mini Works
cross Drilled= street
slotted= track
the slots have a very sharp edge, almost like a knife, they tend to wear pads very fast.
drilled rotors, at least the good ones (like brembo) have a rounded chanfer around the holes.
Most of the drilled quality rotors used in street applications do not crack.
Victor
Old Oct 25, 2006 | 12:53 AM
ripnrik's Avatar
ripnrik
FWIW, I upgraded fronts to Powerslot cryo's and green stuff pads after much wailing and gnashing over drilled, slotted, plain, pad material, etc. Have really been happy, and don't see any accelerated wear. Noticable increase to brake performance despite not doing rears yet. No noise, no squeal, better bling, reasonable cost. Most difficult procedure was finding a torque wrench with the right geometry.
Old Oct 25, 2006 | 03:41 AM
PGT's Avatar
PGT
I've got dba4000's on my Subaru and they are an excellent design. I believe they have apps for the MCS, including the JCW set.
unxpectederror
Oct 22, 2015 12:16 PM
Shomare
39
Oct 19, 2015 03:33 PM
Keet
SCCA Solo and ProSolo
Sep 20, 2015 01:02 PM
Keet
Sep 19, 2015 09:45 PM
Sep 14, 2015 12:48 PM
