R50/53 Fog Lamp
Fog Lamp
I noticed this morning that one of my fog lamps was not working. The dealer wants $22.75 for a replacement. Any other options? I'm talking about the stock one in the bumper, not add ons.
Thanks.
Minzila
Thanks.
Minzila
I think $23 bucks for a maybe $5 bulb is about right from a dealership. And remember that they will probably charge you for labor too LOL
Removing the bumper is very easy. Just do a search for instructions.
Fog Lamp
Thanks for the replies, but I guess what I'm asking is, does anybody know a part number (Oshram, GE, Sylvania). It looks like it can be changed from the wheel well.
Minzila
Minzila
I'd strongly recommend you get some (10 ea) of the plastic screw-clips as they can be mangled / stripped when you remove them.
$23 is not bad if you include the labor.
I think you can take loose the lower screw for the inner fender (actually in the bottom of the bumper cover) and peel it back enough to reach the bulb. That way you can leave the other dozen of the easily strippable screw-clips in place.
Chows says H11, I think they're H7 bulbs. I also think that there was a change sometime during production. Check your owners manual...maybe the bulb is listed there.
HERE IS A VERY GOOD TECH TIP
ALWAYS take a new halogen bulb out of its packaging and clean it with a fresh paper towel and alcohol. Once it is cleaned, handle it ONLY by the metal base. If you touch the glass, wipe it with alcohol again before installing it. The instructions will caution you against touching the bulb, but you don't really know if someone may have touched it at the factory before it was placed in it's package. Do it right, and it'll last a lot longer.
Rawhyde
PS My next post will put me into 5th Gear!
F55/F56 Do I have rear fog lights?
Peking Duck
Jan 19, 2021 03:17 AM
vulkandino
Oct 31, 2015 08:29 PM
