from the pic, you can see that the filter is almost connected to the throttle body itself the reason for that is so the air-feed tube will be closer to the filter
here you can see how near the air-feed is to the filter
whatya guys think?
took it out for a test and the engine definitely feels it can breathe better...in fact, A LOT better compared to my cheapo filter before the upgrade
looks good, but wouldn't it be getting the hot air produced by the engine rather than the cold air from the outside?
Since it's open to air under the hood from all directions, it will always get all of its air from under the hood, but how much of it is hot air depends on whether (and how fast) the car is moving. When standing still, there's no pressure to push air through the snorkle so the majority of the air will likely come from elsewhere in the engine bay. When moving, the air forced in through the snorkle will increase with speed and this will lower the temp of the air surrounding and available to the filter.
