R50/53 Gear Ratio 02
Old Oct 11, 2006 | 01:41 PM
MCSneworleans's Avatar
MCSneworleans
Gear Ratio 02
I am sure the answer to this question is here but I could not find it...the 02's are geared differently than the later models (MCS), true? I drove a 05 and at least through 1st and 2nd the gears seemed significantly shorter than mine. I have heard this has something to do with top speed, ie, the early models theoretically could go 16x, but the later models are geared so that 6 tops out at 135.
Old Oct 11, 2006 | 01:46 PM
chows4us's Avatar
chows4us
go to mini2.com and read the FAQ. All the info is there with top speeds in each gear.
BTW, with taller gearing, the 02 - 04s have theoretically higher top speed but slower acceleration. However, it all depends upon HP (which is lower), aerodynamics, and whether or not there is really a "speed limiter" (which is debatable).
Old Oct 11, 2006 | 11:03 PM
dix's Avatar
dix
I drive an 02 and it seems to lag on third.
GAT
Oct 4, 2015 07:27 PM
micromini234
Sep 30, 2015 07:36 PM
patsum
Sep 30, 2015 02:10 PM
bahman
Sep 30, 2015 01:59 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
