R50/53 Driving Lamps - Secure or What?
Old Oct 2, 2006 | 12:14 AM
El_Jefe's Avatar
El_Jefe
I am buying the OEM's or nothing. I am all about bling. I like them. However, I am concerned with comments about them rattling.
Do they? I wouldnt like that if the do.
Also, someone BEGAN to talk about the rubber nib in the back of them doing something or needing something to be secure.... they never finished explaining . read and searched many threads on OEM lamps.
Does this thing get drilled through the visible grill? That rubber nib looks like it goes through it sort of. Or at least wears out a notch in it after driving a long time with them.
thanx
Old Oct 2, 2006 | 01:49 PM
chows4us's Avatar
chows4us
I had them and never any rattling. MINI uses rivets and they always felt strong to me. I was advised to NOT slam the bonnet down ... just bring it a few inches before closing and let the weight of the bonnet do the work.
Never heard anything about gromits ... no issues there.
Old Oct 2, 2006 | 03:32 PM
qwertmonkey's Avatar
qwertmonkey
Mine are pretty much custom all the way. I have MINI mania brackets, and thats the only recognizable part. I dont have any rattling at all and I didn't even use rivets. I love the look of them, (bling factor here) and hardly use them. Honestly, we haven't had a chance to use them yet!
Old Oct 2, 2006 | 04:14 PM
machineguncharley's Avatar
machineguncharley
I've got them on both of my cars and no complaints as of yet!
Chuck
Old Oct 2, 2006 | 07:44 PM
Rawhyde's Avatar
Rawhyde
I have seen several OEM driving light equipped MINIs. I have never seen one with the rubber bumpers installed. The dealers just skip this step from what I've seen. On a gravel road, or a rough road, there is some vibration in the lights, and it is visible in the beam they project. It is not enough to concern me but your perceptions may be different than mine.
I have the best of both worlds (but it cost WAY too much this way). I had the OEM lights. I thought they sucked, so I swapped them for Cibie Tangos. I still have the OEM switch and wiring which is first rate.
Look in my gallery. I doubt you can tell the difference in the OEM lights and the Tangos, but you can tell a giant difference driving the car at night on a dark road. I prefer a nice clean look, but I value function over appearance.
The Tangos are easily adjustable for elevation whereas the OEM lights tend to "look up" as the bolt is tightened...a pain to aim properly.
Rawhyde
Old Oct 2, 2006 | 08:35 PM
El_Jefe's Avatar
El_Jefe
Rubber Bumpers?
Old Oct 2, 2006 | 10:18 PM
JPMM's Avatar
JPMM
Ditto on the adjustment problems , the stockers are on a kind of ball and socket with a through bolt . Make the adjustment ,tighten the bolt and the light moves right back. I had bend the mounting bracket to get the lights aimed right. The little hokey rubber back stops were frozen and locked up after 3 years old, I repaired them the best I could, until I get a chance to completely change them to something more stout as the lights giggle quite a bit.One word ,cheap.
Old Oct 2, 2006 | 11:11 PM
El_Jefe's Avatar
El_Jefe
I saw the rubber things dried out and dead on used mini's on the lot.
that's not cheap, thats actually pricier rubber normally that does that. It is latex from a latex tree. best kind. needs to be treated for outdoor use with some sort of water based thing like Griot's. but in general, that aiming aspect does suck. I will have to do that when I am at the dealer. aim them there make em work.
Old Oct 3, 2006 | 08:30 AM
WannaMini_'s Avatar
WannaMini_
I have OEMs, and yes, one of mine rattles REAL bad. I think I'll have the dealership take a look next time I'm there.
But I also broke one. Flying road stone - CRASH....
Old Oct 4, 2006 | 06:55 AM
JPMM's Avatar
JPMM
I meant cheap as in cheap all around. The lights are constructed like aftermarket stuff you'd find advertized in the back of a Road and Track in the '60's.
Old Oct 6, 2006 | 12:16 AM
El_Jefe's Avatar
El_Jefe
WEll I bought them. awaiting install on Tuesday. Oem's. They look hot and truly retro, and not clunky.
sevin
May 2, 2026 06:11 AM
Powershift
Aug 16, 2015 05:14 PM
JamJam43087
Aug 16, 2015 02:02 PM
DWooderson
Aug 10, 2015 09:12 AM
