215/40 on 17x7"?
215/40 on 17x7"?
Hey guys.
Going along with my 215/40 vs 215/45 accel question, has anyone put a 215/40 on a 17x7 webspoke? I know it's supposed to go on a 7.5".
My thought is if I stuck it on a 7" rim, the added sidewall flex would negate any benefits I would have picked up by the lower profile. Not to mention the added harshness.
So this is just a 215/40 on a 17x7 question, not a 215/40 vs 215/45 debate.
Thanks.
ZM
Thanks.
ZM
Hey guys.
Thanks.
ZM
Thanks.
ZM
215's fit just fine on a 7", my TSX OEMs are 215/50/17 on 17x7
X 2 (sidewall each side of tire) = 18.45 cm, plus your 17" wheel (43.18 cm) for a total of 61.63 tire/wheel diameter (24.26 inches). 215/45 tire adds an extra .45 X 10mm X 2, which comes to 9mm, or .9cm. So your total wheel/tire diameter becomes 62.53 cm, or 24.618 in. The increase in tire/wheel diameter is only about 1.5%. No problem, very minor speedo dif.
@zack, are you sure their not 7" wide?
You might be right:
http://www.mini2.com/forum/faq.php?f...factory_wheels
I thought I came across something that said the S-Lites are 17x7.5". Maybe the official MINI accessories book? Can anyone comfirm that? I don't have my book close by.
Haha I don't have to worry about snow down here in Florida... Where did you buy the Zenn springs?
Thats what I thought but was not 100% sure... That would make the odometer read less miles than actual correct? Off by only 1.5% though...
Despite many references in the MINI advertising literature dating back four years to the R85 S-lites being 17x7.5"... the wheels themselves actually are marked 7JX17. If I had one unmounted I would measure it.
But a 215 would look and work just fine on either a 7" or 7.5" rim.
That's interesting.
Yeah, at the beginning of this post I was trying to hear from ppl who had mounted a 215/40 vs 215/45 on a 17x7, since it's supposed to go on a 17x7.5".
I've mounted tires on smaller than recommended wheel widths before to find too much sidewall flex, effecting steering response. Sounds like no ones complaining too much here, though.
ZM
ZM
danielo
Tires, Wheels, & Brakes
Feb 22, 2009 09:42 AM
