R50/53 Plastic cap on rear bumper of cooper S
Old Sep 24, 2006 | 05:27 AM
d21998's Avatar
d21998
Hi there, I am a new owner of a "slightly" used 02 Mini Copper S. My question is, there is a small plastic cap on the rear bumper that covers some threads for something to screw in to. What goes here? I lost the cover Friday evening and I can't wait until the dealer opens on Monday. Does anyone know? Thanks in adavance.
Old Sep 24, 2006 | 05:39 AM
jdmarino's Avatar
jdmarino
I believe that's where the tow hook screws into the frame.
I have no idea when a tow hook would be used, as tow trucks are either flatbed (if you;re lucky) or they "sling" the drive wheels.
Maybe ia tow hook is so you can tie a rope from your car to one you are pulling?
Old Sep 24, 2006 | 05:40 AM
shooler's Avatar
shooler
That is where the tow hook threads into. There is one on the front as well.
Old Sep 24, 2006 | 05:46 AM
asodestrom's Avatar
asodestrom
They get used at the track quite often (not on MINI's of course) Our club requires them so they can pull you off the track quickly,
Old Sep 24, 2006 | 11:16 AM
Gromit801's Avatar
Gromit801
Say you slid into a ditch? You're going to have to be pulled out.
Old Sep 24, 2006 | 11:24 AM
chipgrafx's Avatar
chipgrafx
Even on a flatbed towtruck they should be using the towhook. If your car needs to be towed, make sure they use it.
Old Sep 24, 2006 | 01:38 PM
Jeremy1026's Avatar
Jeremy1026
Moderator
Yep, cause if they arnt tieing your car down with the tow hook, the tow truck driver is guessing that part under the car is strong enough to chain down to keep your car from rolling off the flatbed.
Old Sep 24, 2006 | 05:50 PM
JohnMonk's Avatar
JohnMonk
Coordinator :: Nashville–Middle Tennessee MINI Club
You can get that cover from your dealer, but you will have to get it painted. I'd ask the dealer if they have a touch up guy that can shoot it.
Old Sep 25, 2006 | 08:51 AM
sequence's Avatar
sequence
The tow hook proper is located inside your "tool" kit in the boot, next to the battery.
Old Sep 25, 2006 | 08:57 AM
mdsbrain's Avatar
mdsbrain
The tow hook will help save your but when you need to get towed. The driver will use the tow hook to pull the car onto the truck if its a flatbed. This is assuming your car won't run.
Old Sep 25, 2006 | 08:59 AM
El_Jefe's Avatar
El_Jefe
does the average meat head tow guy know how to use these or recognize them? I have had tow guys really F up cars before
Old Sep 25, 2006 | 09:00 AM
mdsbrain's Avatar
mdsbrain
My car has been towed twice and both times I didn't even let them worry about it. I was sitting waiting for them with the hook in already
Afterall it was something to do while I waited for the truck.
Old Sep 25, 2006 | 09:17 AM
everytimeidie027's Avatar
everytimeidie027
man I was always kinda bummed thinking I didnt get a tow hook, I didnt know there was a tool kit next to the battery, when everyone said check your tool kit I thought they meant that bag that stores the jack
Old Sep 25, 2006 | 09:19 AM
mdsbrain's Avatar
mdsbrain
Everyday is a learning process
Aug 7, 2015 05:56 AM
bctf1
Aug 6, 2015 12:55 PM
WayMotorWorks
Aug 4, 2015 01:47 PM
