R50/53 WHOA Is this normal???
Old Sep 23, 2006 | 09:52 AM
Little bit's Avatar
Little bit
I just noticed on my 04 MC that if I leave a turn signal on the turn signal lights stay on!
No key in the car, lights off, car locked but the front, side and back TS light are on solid!
Old Sep 23, 2006 | 09:56 AM
polizei's Avatar
polizei
Yes, going WHOA! while driving a MINI is normal.
I'm not exactly sure if that is normal or not...uhhh, never tried it. Anyway, does it go away, or just stay on forever? My guess would be no, but I could be wrong.
-Cody
Old Sep 23, 2006 | 10:17 AM
camminich's Avatar
camminich
It doesn't sound normal, but could be a Euro thing. I had an old Volvo 780 coupe that would do that the same thing. It was a safety light for when you were broke down on the side of the road. I have only known Volvos and Saabs to have that feature.
Now I don't think the MINI has that option, but I could be wrong. Soooo, it is either a Euro thing that has been programmed on, or an "oops" that might need to be addressed.
Old Sep 23, 2006 | 10:20 AM
gokartride's Avatar
gokartride
If I get your meaning, that's absolutely normal. They are parking lights, presumably useful for narrower European streets. The stalk doesn't have to be in "turn-mode" when you shut the car off either....you can turn the car off and then turn the signal and, whichever way you turned the stalk, that set of lights will come on. It's a very cool feature.....not necessarily all that common/needed around here...but cool nonetheless!!
Old Sep 23, 2006 | 10:25 AM
Little bit's Avatar
Little bit
Originally Posted by gokartride
If I get your meaning, that's normal....they are parking lights, presumably useful for narrower European streets.
I don't think so, if I open my door (car not running) and turn my turn signal on, the lights on that side of the car come on and stay on! This will eventually drain the battery.
Old Sep 23, 2006 | 10:32 AM
MINI-IZED's Avatar
MINI-IZED
It is totaly normal. Refer to the section "Parking Lamps/Low Beams" in your 04 Owners manual. I don't know how long they will stay on.
On a related note, try flashing your brights after you turn the key off. The headlights will stay on for about 30 seconds. I thought the dealer had to program this feature but it turns out that they only program the time the lights stay on. Pretty cool.
gokartride's Avatar
gokartride
Good point!! Best to use only purposefully, I guess.
Old Sep 23, 2006 | 10:45 AM
camminich's Avatar
camminich
I checked another source (European MINI site to remain nameless), and it is very normal.
It is a "Euro thing" intended for a break down. If you are on the right side of the road, you can turn just your right signal on solid, and the same if you are on the left. From what I read, it is something that you can have programmed on our off. I checked, and my 03 does this also. So aside from leaving just all of the park lights on via the dial at the end of the wand, you can also leave the left or right side on.
As stated before, this will of course kill your battery over time. But probably would take a while.
Old Sep 23, 2006 | 10:47 AM
chows4us's Avatar
chows4us
Most all European cars do that. ...
Gokart got it right Tiny streets ... parking lights.
Old Sep 23, 2006 | 10:49 AM
MY4thMINI's Avatar
MY4thMINI
mine does it toooooooooooooooo
Old Sep 23, 2006 | 06:38 PM
Little bit's Avatar
Little bit
Dealer told me today that it wasn't programmable.
Old Sep 23, 2006 | 07:48 PM
OmToast's Avatar
OmToast
Dont' see why it would have to be -- if you don't want to use this feature, don't turn it on. Seems pretty straightforward.
Old Sep 23, 2006 | 07:54 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Yes it's normal...
When you park on a street with no lights, it can be useful... But I've never used it.
I usually get my trunk-monkey out and get him to watch my MINI while I am out lol
Old Sep 23, 2006 | 08:52 PM
MINI-IZED's Avatar
MINI-IZED
I love trunk monkey, especially the theft recovery system!!
Old Oct 19, 2006 | 06:18 PM
200-OK's Avatar
200-OK
Just happened to me today...
This just happened to me today (turn signal on solid after engine off). I must have accidently hit the turn signal as I was turning off my car. Didn't notice it until I got out. I thought something was wrong with the car.
Thanks to NAM (once again), I saved a wasted call to the dealer...
Old Oct 19, 2006 | 06:53 PM
Jtrem's Avatar
Jtrem
doesnt sound "normal" but im sure it wont hurt it. Just turn it off after you turn.
Old Oct 20, 2006 | 10:17 AM
BECOKA's Avatar
BECOKA
My 30 year old 914 does that too. Did not realize there was a purpose.
Old Oct 20, 2006 | 10:38 AM
raym's Avatar
raym
whoa
I must have bumped with my elbow over the weekend when
I was installing a parcel shelf and finishing the foglight wiring.
gave me a heart attack that I had somehow screwed up the
wiring or something under the dash before I figured it out
Old Oct 20, 2006 | 12:32 PM
wilson0728's Avatar
wilson0728
You see this all the time in europe on the cars there along with them folding in their mirrors. I don't think they've figured out about the trun monkey yet though.
acitydweller's Avatar
acitydweller
the car should be on for the signal lamps to work. That definitely isnt normal.
Old Oct 20, 2006 | 12:44 PM
JustJAY's Avatar
JustJAY
I guess you didn't read the whole thread
Old Oct 20, 2006 | 02:05 PM
DaveTinNY's Avatar
DaveTinNY
Cool feature, I'll have to check it out when I get home tonight.
That trunk monkey was a riot!
Old Oct 20, 2006 | 03:52 PM
nilo's Avatar
nilo
Many european cars have this feature and some are programmed to turn off before draining the battery. I was dissapointed to read in the manual that ours will not, although maybe it can be programmed by the dealer.
Old Oct 20, 2006 | 03:56 PM
HighSchoolzMINI's Avatar
HighSchoolzMINI
i think there was something about this a little while back
Jeremy1026's Avatar
Jeremy1026
Moderator
perfectly normal, more of a feature for europe, with their small roads, but...its still a cool thing to have here in the states
Colt45Magnus
Aug 27, 2024 05:03 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
Shomare
39
Oct 19, 2015 03:33 PM
navybsn
Oct 4, 2015 03:27 PM
Miniwaukee
Sep 29, 2015 09:22 AM
