R50/53 What are these?
Old Sep 21, 2006 | 08:34 AM
minibull2's Avatar
minibull2
What are these?
I have an 2006 MCS ... I found these on ebay.
any idea if these will fit an 06 and if these accomodate the reverse light?
Tia.
Doug
Old Sep 21, 2006 | 08:39 AM
Motor On's Avatar
Motor On
Those are 02-04 tail lamps, if you wanted to switch to those you'll need to put a reverse light in the bumper, checkout myminiparts for the equipment needed.
Old Sep 21, 2006 | 08:40 AM
alpinamike's Avatar
alpinamike
Older tail lights, should match up, they were used 2002-2003or 4ish.
alpinamike's Avatar
alpinamike
Beat me by a couple seconds
Old Sep 21, 2006 | 09:28 AM
minibull2's Avatar
minibull2
Thanks for the quick replys!
Minibull
Old Sep 21, 2006 | 09:36 AM
SB's Avatar
SB
I have the 02-04 lights in my 06. Like mentioned. You'll need to buy a reverse light. I think it is below $20. I believe there is also a kit to convert the newer lights to the older car so maybe there is one to put the older lights in a newer car. I just wired it myself. It's not much to it but it's best if you understand the wiring before cutting and splicing then finding the rear fog light wire and using it as power for the reverse light.
The reverse light connection on the newer car is actually the turn signals on the older lights. One of those wires needs to connect into the fog light wire so that you can use the connector behind the bumper. That is, if you don't have the fog light option. The connector is also reversed polarity so that'll need to be fixed. Then the turn signal of the new car needs to be moved to the turn signal of the older lights. Then you can do the fog light mod to make your brake lights brighter.
This is what I did and by no means is it instructions on how to do it. Something terrible can happen if not done correctly which, if it does, I'm sure it will screw something up badly. And I am sure the warranty will not cover it since wires were cut. So don't do it if you're not familiar with wiring.
In other words. Look around for an adapter.
Is that enough of an "I'm not responsible" comment?
Old Sep 21, 2006 | 09:43 AM
Motor On's Avatar
Motor On
It's people like you who make indentifying car on spotted thread local clubs a hard as I try to include year when possible:impatient
If you have the guts to pull it off then you are certainly worthy of a pat on the back though.
Old Sep 21, 2006 | 10:46 AM
SB's Avatar
SB
Old Sep 22, 2006 | 06:06 AM
minibull2's Avatar
minibull2
Reason ...
I appreciate the informative replies.
The only reason I am considering older used taillights is so I can have them tinted.
The condition of the lens (as long as they are not cracked) doesnt matter since they will be sanded down.
MiniBull
