Drivetrain Shifter Nirvana
Old Sep 19, 2006 | 03:14 PM
XAlfa's Avatar
XAlfa
Shifter Nirvana
So, I now have a combination of the Mania SSK, which reduces throw by ~20% and a sweet JCM shift ****, which I've adjusted up to about 3/4" higher than stock. This is an awesome combination, imo. I've got the shifter up closer to the wheel and a reduced throw (I'm guessing around 15%). Feels about perfect to me. Click. Click.
Old Sep 19, 2006 | 07:59 PM
astrochex's Avatar
astrochex
So you made your shifter crappier than before?
You find that shape more comfortable than a ball? Whats the radius on the edge of the top (not the max radius of the shifter)?
Old Sep 19, 2006 | 08:50 PM
sprp85's Avatar
sprp85
So what does the **** do that differs from the other *****?
Looks comfortable, Very. More info please!
Old Sep 19, 2006 | 09:19 PM
1nf3rn0's Avatar
1nf3rn0
The **** is comfortable in the MINI, whereas that would seem like it would be ungainly... In the m3, with the location of the shifter, that style works better....
Old Sep 20, 2006 | 07:41 AM
XAlfa's Avatar
XAlfa
No, my friend. JCW is crap, not JCM.
I do like this more than a ball. Not more comfortable, but pushing/pulling against the straight sides seems to feel more... precise. I'd say the top of the shifter is about 1.25" in diameter.
Old Sep 20, 2006 | 07:42 AM
XAlfa's Avatar
XAlfa
You mean aside from the heat and vibration features?
Old Sep 20, 2006 | 07:45 AM
XAlfa's Avatar
XAlfa
It might seem to be ungainly but, in fact, it is anything but.
Old Sep 20, 2006 | 08:15 AM
astrochex's Avatar
astrochex
So you use your palm then, when you shift? Bondurant recommends you should cradle the shifter like an egg, hence the palm.
The JCM shape looks like it would be comfortable with that technique.
Old Sep 20, 2006 | 09:18 AM
XAlfa's Avatar
XAlfa
And it makes a very nice omelette.
Old Sep 20, 2006 | 09:46 AM
dmh's Avatar
dmh
This style of **** is designed for a sequential gearbox rather than our H-pattern regardless of what JCM says.
Old Sep 20, 2006 | 03:08 PM
XAlfa's Avatar
XAlfa
What's the pattern of a sequential gear box? Never driven one of those, myself, unless you're talking slush box.
Old Sep 20, 2006 | 03:26 PM
ScottRiqui's Avatar
ScottRiqui
Motorcycle gearboxes are sequential, to give you an example. From any given gear, you can only shift to the next higher or lower gear - no skipping past gears.
In cars, most sequential gearbox shifters are of the simple "push away from you to downshift, pull towards you to upshift", and the gear lever is spring-loaded to pop back to the center position after each shift.
Scott
Old Sep 20, 2006 | 04:24 PM
XAlfa's Avatar
XAlfa
Scott
Ah, so are there any "production" cars out there with sequential manual gearboxes? I've only heard of this on dedicated racers.
Old Sep 20, 2006 | 04:41 PM
ScottRiqui's Avatar
ScottRiqui
Here's a link to a page describing BMW's SMG-II Sequential Manual Gearbox:
http://www.toodarkpark.org/misc/cars/m3/smg/index.html
Mercedes and Fiat also have similar setups, with different names.
Scott
RobbyD
Jan 29, 2019 01:22 PM
02miniSguy
Nov 17, 2015 10:29 PM
vetsvette
Oct 1, 2015 12:59 PM
MINI Stupor
Oct 1, 2015 11:36 AM
aldito2
Sep 30, 2015 10:44 AM
