Suspension Problems with control arms
Old Sep 16, 2006 | 12:01 AM
glassintrepid's Avatar
glassintrepid
Ok, i just wanted to see why I am having the problems below. I got some IE control arms to induce some negative rear camber. Well, after i got them installed i went and got an alignment and then everything was peachy. I go around a corner and all of a sudden the passenger rear side of the car feels like it falls off. OK, so i pull over and my wheel is pretty much hanging from the top control arm. WTF, so i look and the rod has separated from the thing that holds on to the axle. The threads are striped... Ok well, i call and the are very good about overnighting me a new one and assure me that this is a first. So i put the new one on(yesteday) and today i was driving home and the same durn thing happens to the drivers side. WTF, so now im out alot of money and im not so sure that i want to put new ones on again... There is no way that i could have installed them wrong, its almost impossible to screw up, its just a jam nut. So, what do you think?
Old Sep 16, 2006 | 05:26 AM
onasled's Avatar
onasled
IE? Irerland?
It is possible you installed them incorectly. How did you do it
Old Sep 16, 2006 | 05:56 AM
glassintrepid
well i got them to stock length and then tightened the jam nut... Both sides had equal lengths.
Yes, ireland.
My computer is being a git.... So, there is one pic...
Old Sep 16, 2006 | 06:02 AM
pmello's Avatar
pmello
Pictures please!!
Old Sep 16, 2006 | 06:23 AM
glassintrepid
Originally Posted by onasled
IE? Irerland?
Is there a wrong way? Because if there is i would like to know about it!
Old Sep 16, 2006 | 06:24 AM
vader's Avatar
vader
Yes, pics please.
When you say "both sides had equal lengths", do you mean that both ends of the control arm had equal amounts of exposed threads or that the arms on each side of the car were the same length?
Old Sep 16, 2006 | 06:33 AM
glassintrepid
Yes, after looking at the part i already have off of the car and the brand new one, without the jam nut it is looser than a goose! On the other end of the bar(there are two kinds of jam nuts), the threads are tight. Im assuming its not supposed to be like this? Arent they supposed to both be tight? I have some more pics, but it will not let me resize them and then post.
Old Sep 16, 2006 | 07:48 AM
cristo's Avatar
cristo
Alliance Member
Could the threads in the center piece be stripped on the side that came apart???
Old Sep 16, 2006 | 08:06 AM
glassintrepid
Well, i guess stripped wasnt the right word. Its more the part that screws in is not large enough to get enough bite on the center piece. The threads are not stripped, but flattened.
Old Sep 16, 2006 | 11:05 AM
vader's Avatar
vader
That sounds like one of the ends is the wrong diameter. If IE has someone else build these for them, they might not notice that there was a problem if the jam nuts were tight. I would let IE know of your discovery right away.
Old Sep 16, 2006 | 03:21 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
The photo you posted shows the jam nut about 1.5" down the threaded section, which means 1.5" of threaded rod --slipped-- out of the Al control arm. The only way this could happen is if the threads did not match (male to female that is). I can't believe IE did this, as my IE control arms have matching threads from what I remember when installing them, and adjusting them - twice. Maybe they shipped the incorrect part. I'd send these parts back to them to confirm what we all seem to suspect.
good luck,
Old Sep 16, 2006 | 06:45 PM
glassintrepid
Ive already gotten some replacements from alta on the car. Im not comfortable using these part on my car after two mishaps. Anyways, they are going back monday after i can get ahold on IE.
Toolman
Jan 20, 2016 06:50 AM
wkp1219
Nov 13, 2015 07:52 AM
maestro39
Oct 27, 2015 02:38 PM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
