Drivetrain Upgraded Lower Engine Mount
Old Sep 14, 2006 | 08:50 PM
batrugger's Avatar
batrugger
I want to know if anyone has changed the bushings for this mount:
If you have what difference did it make? Are there benefits? I upgraded the mount in this location on my VW and it made a huge difference in launching. It drastically reduced the wheel hop that VW's have. Any help is much appreciated.
Old Sep 15, 2006 | 05:04 AM
obehave's Avatar
obehave
The only bushings I've seen are the Powerflex.
I have the uppers and they work fine. The lower bushing sleeve didn't run a tight enough tolerance to the bolt to make me happy. This was pointed out to me by Randy Webb. So I'm not running the lower.
Doing the upper alone did a nice job but did up the NVH a bit.
Old Sep 15, 2006 | 07:01 AM
batrugger's Avatar
batrugger
Thanks Anyone else
Old Sep 15, 2006 | 04:14 PM
rkw's Avatar
rkw
http://www.mini2.com/forum/engine-dr...ne-mounts.html
Old Sep 15, 2006 | 08:12 PM
batrugger's Avatar
batrugger
Thank you, that was most helpful . Any other experiences out there?
Old Sep 15, 2006 | 08:19 PM
Brain1.0's Avatar
Brain1.0
Manufacturer
I have all the powerflex bushings and the engine damper. Engine movement is almost non existant but there is definitly more vibration. But its not that bad. All the power is straight to the ground !
Old Sep 15, 2006 | 08:33 PM
obehave's Avatar
obehave
Do you have steering rack bushings as well?
They're tempting.
Old Sep 15, 2006 | 09:54 PM
TonyB's Avatar
TonyB
I currently have PowerFlex (yellow and purple), but might go back to Delrin at the top or bottom...
http://www.mini2.com/forum/engine-dr...ghlight=delrin
Old Sep 16, 2006 | 07:01 AM
Brain1.0's Avatar
Brain1.0
Manufacturer
They're tempting.
Yep I have those too as well as the front control arm bushings.
Old Sep 16, 2006 | 11:31 AM
batrugger's Avatar
batrugger
Thanks Brian, and it was nice meeting you up in Barstow at the pit stop. I had the CR/B MCS with the uberlondon lightbar like yours...oh and the kilt. I have decided to go with the Powerflex bushings, they aren't expensive so it wouldn't be a big loss if I didn't like them. Is it hard to change the bushings without special tools?
Old Sep 16, 2006 | 11:41 AM
Brain1.0's Avatar
Brain1.0
Manufacturer
easy to change with a jack and simple tools. I think you are thinking of cory with the lightbar like yours. I didnt have my car I was driving the truck/trailer in barstow with chris and emily. I do remember you though.
Old Sep 16, 2006 | 01:18 PM
obehave's Avatar
obehave
Thoughts?
Worth it or not? What changes did you notice?
Old Sep 16, 2006 | 01:40 PM
Brain1.0's Avatar
Brain1.0
Manufacturer
much more precise when entering a fast corner and you can feel the power going to the wheels instantly instead of the sloppy tock setup.
Old Sep 16, 2006 | 01:53 PM
batrugger's Avatar
batrugger
OOOPS, my mistake, I remember now. Well it was cool hanging out with there all day in the oven. Thank's again
W0TM8
Dec 19, 2019 07:50 AM
silence2-38554
Nov 12, 2015 09:39 AM
sabjcw
Aug 14, 2015 07:40 AM
minipopkart
Aug 13, 2015 05:22 AM
