Newb question about new wheels and tires
I'll be the first to admit that I'm a total wheel and tire newb. With that out of the way, I just sold the S-Lites on my soon to be delivered in October 06 MCS
I am planning to go with Rota SubZeroes in 17x7.5, ET45, 4x100 with 215/45/17 GS-D3's. I plan to take the wheels off right at delivery and have my new wheels and tires mounted and balanced ASAP. I was wondering if I should get hubcentric rings for these wheels? If so, is there a particular size I need, or is there only one size for the hub rings? Also, will I need anything else to make sure they can be put on right away?
Thanks everyone in advance. I just want to make sure I get this right the first time, so I'm not scrambiling to find parts at the last minute.
If the hub is not 56.1mm, which is the MINI size, then yes, you need hubcentric rings. Find out the hub size by either going to the rota site or to the vendor from which you bought the wheels. Or wait until someone with the same wheels chimes in. Good luck!
mb
mb
The size of your tires, wheel offset and rim size are fine for a MINI with stock suspension. If you lower your MINI then the tires can rub a little in the rear.
Mini'mon
Aug 16, 2015 04:15 PM
sabjcw
Aug 14, 2015 07:40 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
