Suspension Vibration after lowering?
I just installed the Eibach pro kit, its a 1" front and a 1.2" in the rear and when I get on it real hard it has a slight vibration. Before anybody says the camber is off I know it is slightly but I dont remember any vibration in my lowered honda, is this common?
others have/had this issue. See this thread... I just replaced my M7 springs with Koni coil-overs and the car is now 0.5" lower = more vibrations... it's going back up, not a problem as I bought these to get the Koni shocks...
or you broke the CV joint while you did the install... who knows.
the camber shouldn't be the issue as there are many people running
much more aggressive neg camber up front than wat you probaby
got from just lowering it.
Lowering a car places the CV joints at more severe angles and added negative camber will also add to this problem. Both cause the problem; the stcok CV joints have worn according to their orientation be for you lowered the car. Now, they are being asked to wear a different pattern - hence the vibration.
his front camber is no where even near race settings.
i also noticed he has quite a bit of toe-out on the rear...
might want to get a camber/toe kit and get that back to
zero.
zero.
i would be more concerned about the wandering than just wearing out
your tires.
i think you should get both the camber and toe rods for full adjustability.
but this still doesn't address your issue about vibrations..
your tires.
Has anyone with this problem installed adjustable camber plates to see if the angle of the CV joint and subsequent vibration can be dialed out?
I lowered on Eibach's a few months back. The "wear a new groove" line is bull. Installed new wheels and tires its still there...
There appears to be more threads popping up on this one.
Navigation & Audio HK Replacement With New Components
Filmy
15
Jun 6, 2023 06:27 AM
smdmini
Oct 7, 2019 06:05 AM
