Repairing Paint Chips
Old Sep 1, 2006 | 07:22 AM
PredMini's Avatar
PredMini
Over the last year and 16,000+ miles we've picked up several little paint chips. We've got spots on the PW bonnet and B roof. Nothing real serious. What's the best way to repair these paint chips.
So touch up paint? Vendor?
Technique?
I don't want to apply touch up paint and then end up with a spotted Mini.
Thanks in Advance,
Jeff
Old Sep 1, 2006 | 07:38 AM
StanFrancis's Avatar
StanFrancis
Try Blob Eliminator
Have had great success with this product.
http://www.langka.com/
Stan
Old Sep 1, 2006 | 11:23 AM
agranger's Avatar
agranger
Langka is a great product for nice round stone chips. If they are more like scratches, I've found that touch-up paint and wet-sanding works better (but wet sanding can be a bit touchy, so I recommend practicing on a car you don't care about, an old junker body panel or have a professional do it).
With Langka, you basically apply a 'blob' of touch-up paint and let dry a bit. The Langka then selectively 'melts' the 'blob', hopefully leaving you with a smooth, flush touch-up that is ready for polishing and sealing/waxing. It takes a bit of practice to get right, but the good thing is that it isn't destructive to well-cured (over 1 month) paint, so if you screw up, you are pretty safe.
Old Sep 1, 2006 | 11:55 AM
BE4TNUT's Avatar
BE4TNUT
I just ordered some to see how this works out for my many nasty paintchips. My friend let a paintchip go unattended and is now rusting there, the piece between the hood and the windshild (where the vents are), not good...
BEATNUT
Old Sep 1, 2006 | 12:32 PM
agranger's Avatar
agranger
The little micro paintbrushes that Langka sells are also excellent!
For your friend, he/she may want to look into the fiberglass pens (Langka might sell 'em). They are a small bundle of fiberglass that is held in a plastic sheath. You use the glass fibers as a tiny scrubber to get the wax, dirt and rust out of stone chips before filling 'em in.
Old Sep 1, 2006 | 12:35 PM
PredMini's Avatar
PredMini
Let me know how that works out!
BE4TNUT's Avatar
BE4TNUT
That is a good idea, thank you. I will let him know if he decides to fix it... I dont understand his thought process sometime.
BEATNUT
Old Sep 1, 2006 | 12:40 PM
cooper99's Avatar
cooper99
I also had lots of small rock chips on my aerokit and front bumper. I called the dealer and ordered a factory paint touchup kit. It came by mail in less than 2 days. It believe it was $35 dollars and included a paint and clearcoat tube. The paint's lid has a small brush on it ideal for rock touchups, etc. I also used toothpics to apply the paint to the smaller rock chips. Everything looks great now and I still have 95% of the paint left for next year's touchups.
Old Sep 1, 2006 | 05:04 PM
willymcd's Avatar
willymcd
touch up paint works great with the pepper white, i touched up my bumper and it looked great after some wet sanding, the black roof on the other hand is a pain, it gets dull after wet sanding and you need to add the clear coat to it to make it look nice.
Old Sep 1, 2006 | 05:05 PM
MiniMaybee's Avatar
MiniMaybee
I used the Langka system on my chips; several 1/8" to 1/4" chips on the bonnet and grill area. The hardest part was just being patient enough to let the touch-up paint dry enough to begin. The actual Langka product was easy to use and did smooth out the paint blob flush with the original paint.
After I did the Langka I let the touch-up dry overnight and then did Zaino's Z-PC until the chip was invisible.
I can honestly recommend this product and was pleased with the results.
Chuck
Old Sep 8, 2006 | 04:08 PM
stottsan's Avatar
stottsan
Any photos of the end results would be greatly appreciated.
Got my first chip today on the bonnet (down to the metal, too, quite a clash with Astro Black!) and am thinking about using Langka. I picked up the factory paint kit @ the dealer ($16) but am weighing my options.
Thanks everyone!
andrew
Old Sep 9, 2006 | 02:52 PM
davavd's Avatar
davavd
I have about 6 chips, 4 on the bonnet, 2 on the boot. If you use touch-up paint from Mini, what is the point of the Langka Paint Chip Repair Kit? From what Cooper99 says, the factory touch-up paint kit and some wet sandpaper is all I need.
Old Sep 9, 2006 | 07:49 PM
MiniMaybee's Avatar
MiniMaybee
What Langka recommends is to blob the touch-up paint on so it fills your entire chip. Then after it dries you use their product to smooth the blob out flush to your surrounding paint. So I filled in the chip with touch-up paint and then removed the excess flush to the finish. I don't think there is any doubt that you can do the same with sandpaper - I just did not want to go there.
I figured I can do more damage with an abrasive than a chemical that only removes touch-up paint so I went with Langka. If you feel comfortable with sandpaper on your finish then go for it.
Klenk
GP Talk
Sep 16, 2015 11:29 PM
sempaipaul
Sep 14, 2015 09:16 PM
Gen1Parts
Sep 7, 2015 03:50 PM
