using wider tire than oem '16?
Old Aug 28, 2006 | 08:20 AM
skier-clay's Avatar
skier-clay
I am close to putting new rubber on my '03 MCS. I would like to consider some non runflat tires and the Firestone Firehawk GA-02 is one of the few available in a 195/55 16 size. With the reviews on the Firestone running either hot or cold, I have thought of trying a 205/55 16 as an option with more available tires. Has anyone tried this? I wonder if it changes the handling. Thanks for any feedback.
Old Aug 28, 2006 | 08:26 AM
solberg's Avatar
solberg
It seems most people go 205/50/16 when replacing the 195/55's.
Old Aug 28, 2006 | 08:35 AM
skier-clay's Avatar
skier-clay
Have you heard any negatives to this size change? Any particular brands that seem to have the best response?
Old Aug 28, 2006 | 08:36 AM
Guest's Avatar
Guest
Anyone ever try going with a 215 width on a 16 inch rim? Provided it's 7.00 wide I don't know why it would have any problems (Other than finding the tire). I'd like to get the benefit of weight savings and wider gripping tires (Smaller rims with wider tires). Seems most of the 215 width tires are going on 17 inch rims.
215/45/R16?
215/40/R16?
Old Aug 28, 2006 | 08:49 AM
dave's Avatar
dave
pug poo picker-upper
For autocross I used 215/45 R16 tires on the stock 16" v-spokes. With H&R springs and a 22mm rear sway, I didn't have any rubbing.
Johnna's Avatar
Johnna
I'm running Goodyear Eagle F1 GS-03 tires size 205/50 R16 on 16" OZ Supperleggera wheels. They are working well for me. They were also on sale when I bought them a few months ago.
Old Aug 28, 2006 | 08:58 AM
snid's Avatar
snid
205/50R16 is done quite often - I have been using that for daily driving in the summer for 3 years now.
Like Dave, for the track and autocross I run 215/45R16 with no rubbing, though I have them on 7.5" wide wheels. Daily driving on 215/45R16 with wide wheels would be pretty annoying, although the tires I'm using aren't designed to be quiet and comfortable.
Old Aug 28, 2006 | 09:30 AM
skier-clay's Avatar
skier-clay
Thanks to all for the feedback. There seems to be many more choices in the 205/50 16 size. I was just looking at the reviews for Kumho ECSTA AST and they are consistently better than the Firestone Firehawk reviews.
Old Aug 29, 2006 | 06:39 AM
Johnna's Avatar
Johnna
Just a note: Real world tire width can be different than the labeled tire width and will not fully answer concerns about rubbing. For example, I had a set of Bridgstone Pole position S03s in a 205 width and discovered that they were actually a tad wider than my 215 width Falken Azzinis. When I stacked the two sets next to each other, the Bridgestone stack was taller by an inch or more.
The Bridgstones tended to rub a bit on the wheel arches when bottomed out. Not the end of the world but a bit disconcerting.
Old Sep 11, 2006 | 07:50 AM
mudshark00's Avatar
mudshark00
I am using 225/45-16 Hankook on stock wheels for autocrossing. They seem to work fine.
Old Sep 12, 2006 | 12:38 AM
retroom's Avatar
retroom
I have on 205/55/16 Yokohama AVS 100's and have no problems with them. I haven't noticed any handling changes. The ride is much smoother compared to the runflats. Since the tires are slightly taller than stock size, standing start accelleration is less crisp than with the smaller tire size. My next tires will be 205/50/16. However, I really like the way the 205/55/16's fill up the wheel wells.
retroom
Rennfahrer555
General Discussion
38
Nov 1, 2022 03:04 PM
W0TM8
Dec 19, 2019 07:50 AM
blackie
Oct 2, 2015 07:41 PM
FLYM1N1
Aug 16, 2015 01:15 PM
Dashdog
Aug 10, 2015 06:17 AM
