Interior/Exterior ADDITIONAL GAUGES
Old Mar 31, 2003 | 02:09 PM
Darksky's Avatar
Darksky
Who makes gauges that most closely match the factory tach and speedo faces and bezels. I have the factory extra gauge mount (by the cigarette lighter), and I think I am going to put in a voltmeter and oil pressure gauge set. Or do you think that because they will be at the bottom it would look better to go with black face / orange light combos
Old Mar 31, 2003 | 02:17 PM
jwtucker's Avatar
jwtucker
These are the closest I've found so far:
http://www.autometer.com/hp/2003_catalog/racing/59.html
Old Mar 31, 2003 | 02:35 PM
Darksky's Avatar
Darksky
the Autometer gauges look close, do you know if they are easily converted to orange backlight?
Old Mar 31, 2003 | 03:36 PM
perfpow's Avatar
perfpow
Here are Autometers as I mounted them in my Cooper S.
Old Mar 31, 2003 | 03:39 PM
perfpow's Avatar
perfpow
Here they are at night lit up in orange. They were impossible to focus on at night with the slow shutterspeed. The lights are not backlit like the Mini, but they can be orange.
PerfPow
Old Mar 31, 2003 | 03:49 PM
Darksky's Avatar
Darksky
Of how much use is the boost gauge on a dailydriver? What do you use it for( I know ..TO MEASURE BOOST), but what does it tell you on a daily basis) Is that information valuable enough to need to be constantly monitored, or is just checkig boost during tuning adequate. Does it tremble constantly, I mean are the variations as you drive so great that the info is really kind of useless? Are there any possibilities of the sending unit leaking? Why no Voltmeter? I am not trying to dog your selection of gauges, I am just trying to decide what I need. I wonder if oil temp or head temp might be more important than boost.
Old Mar 31, 2003 | 04:07 PM
Ryephile's Avatar
Ryephile
Perfpow's gauge selection is right-on for his application. He needs water temp to compensate for his Nav not having one; Oil pressure is a critical gauge regardless, and Vacuum/Boost is the Fun guage. Voltmeter is relatively useless on modern cars cuz they monitor voltage themselves. Ammeter would be fun to see though!
Darksky, you don't need any more gauges than what the MINI came with. If you decide to add gauges, keep in mind that it's all for fun anyway. Doing a head-temp gauge while having a water or oil temp gauge is kinda redundant, unless you're racing! Pyrometers, Air/fuel ratios, and trans temp gauges are more racing-esque stuff, and won't be too useful in daily driving.
Good luck, Cheers,
Ryan
Old Mar 31, 2003 | 04:13 PM
Darksky's Avatar
Darksky
I guess I am just used to having oil press,water temp,and volts. I am looking for a way to justify changing from my old school mentality and repalcing the voltmeter with boost.
Old Mar 31, 2003 | 04:18 PM
Ryephile's Avatar
Ryephile
Perfpow: What material did you use to fabricate your Gauge Panel?
Cheers,
Ryan
Old Mar 31, 2003 | 05:19 PM
npartist's Avatar
npartist
MINI sells aux. gauges too. Granted it will cost more and you only get too but I figure it is an option and you do get a warranty. The part number is: 82 94 0 148 956 And they cost $250 uninstalled.
Here is a pic:
Old Mar 31, 2003 | 06:25 PM
perfpow's Avatar
perfpow
Hi Ryan,
Thanks for answering Darksky's questions. A blown engine without a boost gauge is like a day without sunshine! I don't like driving a turbo or supercharged car without a live vacuum/boost gauge. A live gauge has no peg to rest on at zero. It moves with throttle inputs and shows below zero at idle, light throttle and on decelleration. On heavy throttle and full throttle the needle springs instantly to the boost available at that rpm. It finds zero when the engine is off and at part throttle. Boost on our MCS' peaks at full throttle at the redline.
Gauge selection is up to the individual. You could have inside temperature, outside temperature and a hygrometer, I guess. I got exactly what I wanted.
The panel is aluminum and I intend to sell these at Perfect Power. Our website is: http://www.perfectpowerinc.com
PerfPow
_________________
<IMG SRC="https://www.northamericanmotoring.co...ized.jpg" IMG> SPUD
Old Mar 31, 2003 | 08:55 PM
ozmale's Avatar
ozmale
Any one know the best place to tap into the vacuum line for a boost gauge ?
Old Mar 31, 2003 | 08:59 PM
'*Ace*''s Avatar
'*Ace*'
Perfpow-
That is a sick pic! Those gauges fit right in!
Old Mar 31, 2003 | 09:04 PM
kesh420's Avatar
kesh420
Check out this post I have on the boost guage install:
https://www.northamericanmotoring.co...amp;topic=3636
PM Me and I'll tell you where to tap in... no drilling !
Kesh420
Old Mar 31, 2003 | 09:12 PM
minipop's Avatar
minipop
You might want to check out these that mount adjacent to the tach. They only have a volt and boost for the MCS, but I like the idea of having the guages in my line of sight.
http://www.bmpd.com/promini/contents.shtml
Has anyone installed these, who can give us an idea how hard they were to install?
Old Mar 31, 2003 | 09:23 PM
rrmixn's Avatar
rrmixn
There is a company named Omori Meter that is supposed to have matching guages for the Mini & WRX. I couldn't find them on their web site but you might be able to call them to find out.
Old Apr 1, 2003 | 05:19 AM
Davbret's Avatar
Davbret
Here's a link to the Omori MINI guages. Last I heard they will not be brought to the US market. But they are spot on in look....except that this car has a supercharger, not a turbo...so the "turbo" guage is misleading, should be "boost".
R
Old Apr 4, 2003 | 05:41 PM
LetsMotor0_0's Avatar
LetsMotor0_0
Nice looking setup!
I just got my Coooper S last week, with Nav, and am very interested in this gauge setup. How difficult was the installation? Did I understand that you are selling this gauge pod?
Old Apr 6, 2003 | 07:19 AM
perfpow's Avatar
perfpow
Hi LetsMotorO_O,
Welcome to MCO. I will sell the gauge package you see in here with your choice of gauges. I'm at home today, but if you call me at work tomorrow, 847-367-8837, I'll give you a price with the gauge combination shown here on this thread.
PerfPow
(Sol Snyderman)
Perfect Power Inc. (www.perfectpowerinc.com) website up Monday PM or Tues. It's been under repair/modification for a few months!
_________________
<[IMG] SRC="https://www.northamericanmotoring.co...ized.jpg"[IMG]> SPUD
M7Speed
Jul 10, 2018 09:26 AM
Tires, Wheels & Brakes
Oct 1, 2015 12:18 PM
Alpha Motoring
Oct 1, 2015 10:30 AM
M7Speed
R61 :: Paceman Talk
Oct 1, 2015 06:57 AM
