Suspension screach bump alignment
Old Aug 7, 2006 | 05:45 PM
eurekame's Avatar
eurekame
I did a u turn in the rain unsucsesfully a few weeks ago. Impact was flat a against the rim to a curb at full lock. Visual damage to the rim. Steering wheel was not centered and the car handled like a yugo. I had the rim reconditioned. At the advice of the alignment shop I had them replace the the strut. I also opted to replace the hub bearing assembly. The shop tried to do an alignment but was unsuccesful. They did not charge me.
These are the specs after their attempt. I have Eibach springs with 214/45r17 tires on a 2005 Cooper s
CAMBER L -.07 R -.1
CASTER L 4. R 3.7
TOE L .16 R .15
SAI L 12.4 R 12.5
CROSS CAMBER -.6
CROSS CASTER .3
CROSS SAI -.2
TOTAL TOE .31
REAR
CAMBER L -2.5 R -2.6
TOE L .39 R .31
CROSS CAMBER .1
TOTAL TOE .69
THRUST .04
I have looked at the shock towers and the right tower may have a slight push up.
Currently the car pulls slightly to the right and left hand turns have understeer. I am looking for advice on what to pursue next. Are there any cross measurements I can take to determine where the damage may be located. Thanks for any help.
Old Aug 7, 2006 | 05:52 PM
mitchman's Avatar
mitchman
That doesn't sound that out of wack to me. Make sure the toe is correct and go ahead and drive it as long as your sure the a-arm isn't cracked or something.
It might not have quite as much grip on the Left Front, but I doubt you'd notice it unless you were racing the car or something. The max spec is L -.5 so you're not that far out. Now if it was something like L +1.0, then I would be worried.
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
Keet
Suspension
Aug 30, 2016 03:46 PM
wildwestrider
11
Jan 29, 2016 05:06 PM
rt808
Sep 29, 2015 03:15 PM
daviday
Sep 25, 2015 01:31 AM
