Interior/Exterior Requesting INFO on Wiring a Push Button Starter
Old Jul 22, 2006 | 02:46 PM
qwertmonkey's Avatar
qwertmonkey
And anyone please shed some light on the subject? Assuming I have the momentary push button, how would I go about wiring it?
Old Jul 22, 2006 | 05:14 PM
chows4us's Avatar
chows4us
There are many kits including a standard MINI OEM part http://www.realoem.com/bmw/showparts...03&hg=61&fg=95
but also a JCW button now and MOSS sells them as well as some other vendors
Maybe this helps https://www.northamericanmotoring.co...1&postcount=52
It seems popular in the UK and here is one thread with a wiring "reference"
http://www.mini2.com/forum/interior-...starter+button
Old Jul 23, 2006 | 02:47 AM
Mugami's Avatar
Mugami
Coordinator :: River City Minis
When i get my car back from the shop ill see about taking some photos of an easier way of doing the Button. Currently its getting more go fast parts installed.
Old Jul 23, 2006 | 06:46 AM
qwertmonkey
There are many kits including a standard MINI OEM part http://www.realoem.com/bmw/showparts...&btnr=61_2003& hg=61&fg=95
Maybe this helps https://www.northamericanmotoring.com...1&postcount=52
Thats. There's a lot of helpful info in there!
Thanks. I am really looking for the eaisest possible way. I can route a wire, I can splice a wire. If you have some miracle way of doing it, PLEASE share! lol Thank you.
Old Jul 23, 2006 | 11:49 AM
thirdraildesignlab's Avatar
thirdraildesignlab
Too bad you have to still have key in ignition in order to use it...
Old Jul 23, 2006 | 02:14 PM
Mugami's Avatar
Mugami
np.. just heard from MINI that my starter is out again and there having to order another one.. from what i remember i ran the wire up into the steering column strip and pushed them up the switch in the column just off top of my head i cant remember which colors and spots. From what MINI told me i should have it back Wednsday or thursday.(maybe)
Old Jul 23, 2006 | 04:03 PM
qwertmonkey
Thanks. I am next to clueless, so when you take pics, please be generous!
Thank you.
Old Jul 27, 2006 | 07:24 AM
Mugami's Avatar
Mugami
Cars back. and i took a look under the colum and yes thats where i ran them. I attempted to take some pix. but the camara and me dont do to well on upclose shots. Ok there fuzzy and heck and i havent a clue on how to do the lighting. In fact there pretty much useless but ill post them up in a little bit. but basics.. after you remove the lower portion of the steering colum by removing the 2 #30 torq screws. You will see the back end of the key switch with the wires comeing down.. The Big red wire and the Black wire with the blue stripe are the two you need. For my install I use 14 gauge wire striped about 1 inch folded the barewire in two and wedged it up in the switch for both the Red and the black with blue stripe wires. Then zip tied them to the wires them selves so it wouldn't come loose. Then run the wires the the Start button one on each side. By doing this the key still will start the car. or you can use the button after the key is in the on position. Also this will keep the Clutch saftey switch in working order. In otherwords if you don't have the clutch pedal pressed down it won't start. One main advantage to me is . IF i should stall the car for what ever reason. i dont have to reach for the Key turn it off then back on to start it.. I just have to hit the button.
Hope this helps some. like i said give me a few minutes and ill post the very very fuzzy pixs
Old Jul 27, 2006 | 07:41 AM
Mugami's Avatar
Mugami
ok here are the shots.. remember i sux at this ..
Shot of my starter button. as you can see its pretty much worn.. and yes i have two rows of switches.
This shot shows one of the two screws you have to remove
again sorry for the quality. this one shows the back side of the switch with the wires coming down. There are two Red wires in the shot you will see the zip tie on the one farthest to the right side. This is the wire im tying into.
again sorry for the fuzzy shot.. but it shows the zip ties to the red and black wire.. also it points out the red wires is closest to your seats.
Old Jul 27, 2006 | 07:44 AM
Kentiki's Avatar
Kentiki
Don't put your pics down! They are a huge help. I've been thinking about doing this mod too, and your write-up has made it much clearer in my head (which is far more blurry than your photos)!!
Thank you
Old Jul 27, 2006 | 09:56 AM
qwertmonkey
Thank you so much! Thats a TON of help!
I think that I'll give it a shot. It seem so easy!
Old Jul 27, 2006 | 01:44 PM
Mugami's Avatar
Mugami
it is .. took ten minute from start to finish to do. Originally was posted on mini2 but i was unable to find it. Also forgot the persons name who i really would like to give credit for it.
Old Jul 27, 2006 | 01:52 PM
ImagoX's Avatar
ImagoX
I shudder to imagoine what must be on that second row of buttons... Let's see, there's "Ejector Seat", "Rear Bullet Sheild", "Oil Slick", "Missile Launcher", "Smoke Screen launcher", and... oh, yes, "Push Button Start", but what else...
Old Jul 27, 2006 | 02:26 PM
Mugami's Avatar
Mugami
Button are in order. since i used this car for many things.
() Start button () Neon () 110 volt () strobes () Nitro arming () Purge button ()
Old Jul 27, 2006 | 02:35 PM
Chumley's Avatar
Chumley
oops.. wrong thread
Old Jul 28, 2006 | 09:38 AM
qwertmonkey
I started working on it, but I am stumped. Where should I mount it??? I dont want another row of toggles, and I want to keep my DC outlet. Any Ideas!
Ugg....I AM STUMPED!!!
Old Jul 28, 2006 | 09:47 AM
Mugami's Avatar
Mugami
do you use the cup holders for anything except change =)
If not make a small plate to cover one of the two holder and mount your button to it .. that is if your going to use the big engine start button.
or depending on what you have from the factory try next to the Mirror adjusters if theres space.
Old Jul 28, 2006 | 11:10 AM
qwertmonkey
The cup holder is a good idea. I have heated seats, so next to the mirror ajustors isn't an option.
I'll let you know what I do.
Old Jul 28, 2006 | 11:45 AM
Kentiki's Avatar
Kentiki
Be sure it's not somewhere where it'll get pushed when you don't want it to--like by curious passengers--since pressing it while the engine is running would be bad.
I was thinking of putting a start button in the dash where the OEM one is meant to go, but that's pretty much irreversable. Also I wanted to put it where the button is for the dash light brightness. It would fit perfectly, and I mean how often do you really need to access the dash brightness button anyway!? The hardest part would be relocating that button, not to mention taking the center dash apart.
Old Jul 28, 2006 | 07:16 PM
qwertmonkey
i just got it installed. It was so easy, a 2 yr old could do it.
Old Jul 28, 2006 | 08:00 PM
Kentiki's Avatar
Kentiki
That's about my level.....
Old Jul 29, 2006 | 04:29 PM
qwertmonkey
It was so easy. I'll have to post a how to later. As to the whole "the car wont start without the key, I came close. I got the alternator to start up, but it wouldn't turn over. But I dont want it to start without the key!
Old Jul 29, 2006 | 05:15 PM
Mugami's Avatar
Mugami
Dang i need to make the photo's a bit more out of focus.
btw where did you end of putting the button.
Old Jul 29, 2006 | 07:36 PM
qwertmonkey
I put it in the cup holder!
Old Jul 29, 2006 | 07:37 PM
qwertmonkey
Heres a VID!!!!!! There is an annoying ad that sounds like a buzzing noise. Its not the car.
http://s66.photobucket.com/albums/h2...nt=STARTER.flv
