R50/53 Rattles/Vibrations from back
hi guys,
i was having a discussing with a buddy about this.
anyone having problems with vibrations or rattles from the back area of car.
if so what is it or what can it be?
cheers
and if so, how did you fix it? we were just wondering? thanks
cheers
Originally Posted by MINIclo
Can you be a bit more specific about where the sound is coming from? Is it inside or outside? Is it a rattle, a squeak, a vibration, a buzz, or what?
Originally Posted by caminifan
How about info on when the sound occurs (acceleration, going over bumps, and, and, and...)?
Well since we are on the subject...I've noticed a noise coming from the rear (sounds like right side) and inside the car (but you know how sound can be tricky-could be outside). But I always thought it was something with my kids child seat. But the other day I took the seat out with all his toys and the noise was still there. The rattle sounds like 2 small pipes (hollow sounding) taping together when going over bumps or rough roads. Anyone get this?
Have you replaced the stock rear sway bar??? Then it is most likely that:
- the collars that hold the sway bar to the frame might be just a little bit loose, causing it to bump against the frame
- if the sway bar has locking collars of ends, to prevent lateral movement, one or both may have slipped or became or
- the bushings need to be greased again.
Good luck
Originally Posted by paddy
If you have not replaced the sway bar, then #3 above could also be the cause of you noise. Grease does wear out after a while....
Originally Posted by takingcurves
i noticed a rattle in my trunk ... turned out to be the light cover ...glued it down and still heard noise then i moved on to the license plate .... now shes quiet
So did anyone actually ever figure out what this is? I have the same rattle coming from the back right section when going over ruff sections of road. Usually doesn't happen on one bump but multiple bumps will make it rattle.
Navigation & Audio My 07 COOPER S has an mp3 jack STOCK!
surfblue
Oct 24, 2018 01:20 AM
Aug 12, 2015 01:24 PM
