R50/53 Speed Shifting the 6 speed?
Today I attempted to speed shift my MCS from 1st to 2dn and it would not engage 2nd. I may have hit the gate but I don't think so. I describe speed shifting when the pedal remains mashed while banging the clutch and shifting. I can do it in my TDI NB. Has anyone else tried this with the 6 speed?
My question is why do you want to speed shift? It's not so great for either the clutch or engine; it really isn't worth the benefit unless you're in a short sprint--and even then it's only going to help you if you hit it right. But you're going to wear everything out sooner if you push it.
I didn't really understand the speed shifting part, but when I go into full throttle and shift from first to second, I have the same exact problem. I've tried it several times, and I think I only caught second once or twice, and it was a great feeling. But that's the thing that's bothering me the most about my MCS right now. If you figure it out let me know.
hmm what year MCS.. i have an 03 which ive been drag racing and now Autox. currently car has just over 45k. with over 12k done with Speedshifting. I'm also using a Stage 3 clutch which changes where on the pedal it starts to engage. I found if using the stock clutch it would begin to engage at the first 1/4 inch from the floor which would make it easy to hit the gates and have the problem you described. With the Stage 3 its only 1" of movement from the top of the pedal to go from full engage to disegage which makes it much much easier for speedshifting.
reverse01134
Sep 1, 2015 08:50 AM
Colt45Magnus
Aug 12, 2015 06:43 AM
