Interior/Exterior how to cut CF sheet?
Old Jun 15, 2006 | 09:53 PM
kenchan's Avatar
kenchan
My wife bought me a raw carbon fiber sheet (A4 size) in Japan last
year and it's been sitting on my work bench foreever... i want to
make a small switch plate trim for my car (G35C door handle area).
how the heck do you cut CF sheets? knives would dull, obviously
scissors the same... do i use a saw or something even on like a
1.5mm thick sheet and sand it down? im not too good on dremel
tools as i want to get a nice clean line.
any suggestions?
thanks.
Old Jun 15, 2006 | 10:01 PM
not-so-rednwhitecooper
reciprocating saw
treat it like fiberglass
Old Jun 15, 2006 | 10:16 PM
kenchan's Avatar
kenchan
yeh, i guess i can use a coping saw with small pitch blades...
and finish off with a file. anything that will reciprocate too fast or
use large blades will crack this sheet. it is pretty brittle.
Old Jun 15, 2006 | 10:31 PM
MSFIT's Avatar
MSFIT
exacto knife?
score and break?
Old Jun 15, 2006 | 11:48 PM
willymcd's Avatar
willymcd
saw it, you can splinter things up by scoring and breaking
Old Jun 16, 2006 | 03:57 AM
onasled's Avatar
onasled
For CF that thin you can use a jig saw or even better a band saw with a very fine blade, like a metal blade. It can then be sanded with any sandpaper. Just be careful of any splinters and sharp edges.
Old Jun 16, 2006 | 06:35 AM
JS's Avatar
JS
It cuts like any other fiberglass. Be careful of the dust. Wear a respirator or at least a dustmask.
You can use masking tape on the surface, mark the tape where you want to cut; cut, sand, file to fit. Tape also helps to protect the surface you don't want marred.
Old Jun 16, 2006 | 07:00 AM
ImagoX's Avatar
ImagoX
I've never cut CF, but that tape thing mentioned above works great on fiberglass... And masking tape can be drawn on with a pencil, assuring a really clean line. I've used a band saw with a fine blade and it worked great, but really do listen re: dust- that stuff's killer.
gar56
Nov 15, 2016 06:41 AM
ahorvath
Oct 3, 2015 01:13 AM
BossyR56
Sep 28, 2015 11:33 AM
EVMini
Sep 28, 2015 10:20 AM
