2004 Mini engine not running right
Old Jun 10, 2006 | 04:23 PM
timmiller's Avatar
timmiller
Hey gang I have 2 problems with the engine on my 2004 non-S Mini.
1. It doesn't want to idle, it wants to quit. If I hold the gas down it runs smooth at 1000 rpms and higher.
2. When it hits 2000 RPMS exactly, it acts like its hitting a rev limiter.
This car has sit for several months after being involved in a crash. It has a new ECU which was programmed by BMW. There are no fault codes, and no vacuum leaks, no check engine light.
I'm hoping part of the problem is maybe bad gas. The 2000 RPM issue has me stumped though. I thought I read that in park or neutral, the rev limiter is at 4000 RPM. This is at 2000 on the nose.
Any ideas?
BTW thanks to all who responded about my ECU programming problem. It turned out it wasn't a problem at all with my elec system, it was with BMW's software.
Old Jun 10, 2006 | 04:54 PM
kapps's Avatar
kapps
Are the SES or EML lights on? Sounds like you're in limp-home mode.
Old Jun 10, 2006 | 05:25 PM
timmiller's Avatar
timmiller
what the heck is limp home mode? I didn't see any lights lit up at all, but i'll double check.
Old Jun 10, 2006 | 06:24 PM
polizei's Avatar
polizei
It goes on when you redline the car. The car will then go into "limp" mode, which does just that, limps home! You cannot go fast...so it's basically like a safety for the car, so the engine, etc. won't get messed up, blow up, etc.
Try changing out the gas, checking the spark plugs, and try reseting the ECU if you can (unhook the battery for a night?) and start it up a couple of times. If that doesn't work....I'm clueless, take it to the dealer.
-Cody
Old Jun 10, 2006 | 06:44 PM
kapps's Avatar
kapps
Yeah, limp home mode basically lets the engine rev to just over 2k rpm. Ours went into it when the wiring harness went faulty. Its weird that there weren't any warning lights.
Old Jun 10, 2006 | 08:14 PM
Tüls's Avatar
Tüls
Turbius Maximus
try getting a new coil pack... had a car with a screaming demon doing the same thing... put a new stock one on and it was fine... wierd I know ...but what can ya do...
Old Jun 11, 2006 | 03:48 AM
timmiller's Avatar
timmiller
I can't see the car till later today (3pm or so east coast time). When I do, I'll double check for those lights (SES or EML).
I don't know if it was redlined, since I bought the car just after it had been wrecked, and needed front end repair, and it got a new ECU from BMW.
I wonder if during the collision it somehow got redlined. Nonetheless, the dealer ran the diagnostic on the computer, and there were no faults. I'm sure they know what limp home mode is, and would have checked it for that.
I'll try the different things you guys mentioned and report back later today.
Tim
Old Jun 11, 2006 | 08:29 PM
timmiller's Avatar
timmiller
Here's what I found. No SES or EML lights on. When put in gear, the RPMs are not limited to 2000. Only when in park or neutral.
The car still runs a little rough but is improving.
It will idle as long as you ease off the throttle slowly. It seems like I need to give it gas while starting.
I'll take it for a short drive when i get back to the car again on Thursday. Hopefully I'll have good news.
Old Jun 12, 2006 | 10:12 AM
polizei's Avatar
polizei
Did you unhook the battery and let the ECU reset like I suggested? Maybe that'll fix it?
-Cody
Getrieben
Sep 12, 2024 07:03 AM
09R56
Nov 16, 2022 10:49 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
