Interior/Exterior Driving lights-Bolts instead of rivits.
Has any one used bolts, lock washers and nuts instead of rivits? Are there any risks with going that route?
Thanks,
William
Thanks,
William
I have bolts on the fogs. They do loosen up. But, you also want to be able to adjust them. I can't adjust (I dont see how) the driving lights. A little bit of locktite will do the trick
The deal with the brackets is you are drilling into the plastic grill as well as the thin metal on the bottom there is no way to put a nut and bolt. Thats why the rivits. Do your lay out of the brackets and you will see what I mean.
That is kind of what I did, but I did it the other way around; nut on bottom.
Hmm. I used nuts and bolts with no problems. It was a little tricky, but nothing unusual.
I stand corrected. The rivits done correctly don't show from the outside.
Ohhh! I gotch ya. I dont notice the bolts, no its fine by me. I guess its personal preferance.
You better believe it! If any one disagrees, thay aint a true MINI owner!
That's whats cool about the Mini. It is all personal preference. Everyone has the perfect Mini for them. There is no other car on the market like it.
I used rivets on the grill and nuts/bolts on the bonnet, only because the brackets didn't quite reach the underside of the bonnet and rivets wouldn't have worked. I guess they changed the underside of the bonnet slightly for '06?
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
ryGuyMCS
Oct 20, 2015 02:24 PM
Aug 19, 2015 09:12 AM
