Electrical Help, no air out of vents!
Old May 28, 2006 | 06:12 AM
MINInurse's Avatar
MINInurse
Nationally Known Nurse
We installed the auto up chip and now we can't figure out why there isn't any air coming out of the front vents!! I unplugged the air again, tried to rotate it, thinking that maybe it was in wrong and nothing. Anyone have a solution, or do I need to go into the garage?
Old May 28, 2006 | 06:26 AM
TWISTER's Avatar
TWISTER
fuse?
Old May 28, 2006 | 07:51 AM
MINInurse's Avatar
MINInurse
Ok, where is that located...you have to excuse my noviceness of knowing about my car.
My husband doesn't think that is the problem, air comes out from up top (by the windshield) and in the footwells, but just not out of the front vents. Is that a fuse problem?
Old May 28, 2006 | 08:04 AM
chows4us's Avatar
chows4us
From Bentle thru 04
Left kick panel, check F29, 5 amps A/C control panel
Old May 28, 2006 | 08:19 AM
MINInurse's Avatar
MINInurse
No, fuse is intact. But at least now I know where my fuses are! Still don't have an idear what is the problem?
Old May 28, 2006 | 08:48 AM
chows4us's Avatar
chows4us
OK, try F31 30 amps Blower
and this is more tricky, its Fuse Panel #3 by the left strut tower. FL11 50 amps Heating & AC blower. BUT to get to it you need to remove, disconnect the battery negative terminal, the ECU module and airfilter housing and its on the BOTTOM I wouldnt bother.
An easier one to check is F07, top left of same fuse box, 30 amps, AC compressor.
Old May 28, 2006 | 12:37 PM
MINInurse's Avatar
MINInurse
OK (in the most sheepish voice possible) Yikes! Maybe I will just wait a bit...
Old May 31, 2006 | 02:21 PM
MinigalCS's Avatar
MinigalCS
Coordinator :: Mini Owners of Northeastern Ohio (Mini NEO)
Are you sure that they are in the open position?
Old May 31, 2006 | 04:04 PM
Wagnbat's Avatar
Wagnbat
Uninstall the auto up, and see if that fixes it.
If so, you'll know the cause, and finding a fix may be easier.
Old Jun 2, 2006 | 09:20 AM
JustJAY's Avatar
JustJAY
Yes, all the vents are open, that was the first thing I checked. Actually, I remember it happening before the auto up chip going home from the Dragon. It is strange, we have the auto A/C and there are selection buttons on the right for defroster, vents, and feet. The air, as of now, comes through the feet and defroster. If I select the feet, it stays the way it is. If I select defroster, it also stays the same. No matter which selection I choose, it stays the same. The buttons light up indicating activation, but no change. Checked all the fuses I could get to, but nothing.
Old Jun 23, 2006 | 07:26 PM
pcnorton's Avatar
pcnorton
Maybe you knocked a wire loose during install?
paul
Old Jun 23, 2006 | 11:32 PM
002's Avatar
002
Don't mean to leave you with a cliff hanger, but if you still need help tomarrow I will give you instructions on how to re calibrate the flap motors.
minimofo
Sep 30, 2015 12:26 AM
Sep 10, 2015 11:55 AM
M7Speed
Sep 3, 2015 07:48 AM
Ntety
Sep 2, 2015 08:39 PM
