Suspension Weight jacking?
Old May 25, 2006 | 06:20 PM
MSFITOY's Avatar
MSFITOY
Weight jacking?
What is the ideal weight distribution for a Mini with coil-overs?
Old May 25, 2006 | 07:08 PM
onasled's Avatar
onasled
Sid,
Don't know that it's ideal, but this is how I was running my Mini last year.
Old May 25, 2006 | 07:10 PM
MSFITOY's Avatar
MSFITOY
That's great information...Thanks Greg I'm curious...how did they adjust your struts? With the wheels off and sitting on blocks ontop of the scale or how did they get to the adjusters in the front? And I assume you were sitting in the car?
Old May 25, 2006 | 07:13 PM
Dr Obnxs's Avatar
Dr Obnxs
You're not really moving any weight..
but more leveling the suspension... We're stuck with the fact that the engine is right over the front wheels, and pretty much nothing is over the rears. No ralistic amount of corner balancing will ever shift that.
BTW, those numbers look good!
Matt
Old May 25, 2006 | 07:19 PM
MSFITOY's Avatar
MSFITOY
Matt
I'm glad to see you chime in Matt So a 66/33 is more or less good balance for the Mini then?
BTW...did you get my PM about the TB results?
Old May 25, 2006 | 07:28 PM
Dr Obnxs's Avatar
Dr Obnxs
You don't really have much choice on the weight distribution.
and most of the easy lightening items don't take weight off the front...
Like removing the rear seats and going to a race battery. Closer to 50/50 would be better, but there's just no way to do it with our cars (without major surgery).
Matt
Old May 25, 2006 | 07:35 PM
MSFITOY's Avatar
MSFITOY
I'm looking forward to Greg's weight balance after his "major" surgery
Old May 25, 2006 | 07:46 PM
onasled's Avatar
onasled
Wheels are left on. Rear coilovers can be adjusted from laying on your back. Fronts can be adjusted by just jacking the front of the car and reaching in the wheel well over the top of the tire. The coilover locking rings are above the tire.
It can take hours, but I was incredibly lucky as my car was almost 100% dialed in so it only took about one hour to fine tune it.
I think shops charge about $300 to do this job. I did it myself and I treated myself to some Mint Milanos ...
Old May 25, 2006 | 07:49 PM
MSFITOY's Avatar
MSFITOY
Old May 25, 2006 | 07:53 PM
SpiderX's Avatar
SpiderX
I sat in the car while 3 guys did a lot of work for a few hours.... no idea what they did....other than I saw the tools they did it with and how they affix to the coilover.......but I could not rmember how they adjusted the front
Greg, what is your estimate for weight distribution?
Old May 25, 2006 | 08:01 PM
onasled's Avatar
onasled
I'm not sure at all what will happen when I put the racecar on the scales, but I'm doing as much as I can to get some weight in the back, including myself. I might assume that it will still be about a 60-40.
Old May 25, 2006 | 08:09 PM
SpiderX's Avatar
SpiderX
When do you think you will roll it out and start to test it at the track......do you have a projected date?
sorry to HJ the thread
Old May 25, 2006 | 08:16 PM
onasled's Avatar
onasled
I really thought that it would be this month, but now I just hope it's by August.
Old May 25, 2006 | 08:20 PM
SpiderX's Avatar
SpiderX
OUCH.....but it will be a hell of an August
Old May 25, 2006 | 08:47 PM
DeadEye's Avatar
DeadEye
Supposedly the whole concept behind corner weighting is to have that car balanced diagonaly, which it looks like it nearly was ...
No amount of suspension work could shitf any usefull amount of weight to the back from the front ,( changing the center of gravity ) otherwise you would be driving in the Wheely position - front wheels in the air !
Old May 26, 2006 | 02:21 AM
J Propane's Avatar
J Propane
Greg has a special feature built in his spreadsheet and as soon as the the total weight comes down below 2,000 lbs, a smilie authomatically appears with a beer in hand.
Old May 26, 2006 | 03:06 AM
onasled's Avatar
onasled
Ah ah Ahhhh .... you said below 2200....!
Come come on now Alain, .... don't take away my drive here .
Old May 26, 2006 | 03:18 AM
SpiderX's Avatar
SpiderX
This reminds me of my friend who races "historic fomula 1" 600 whp @ 1100 lb. Is that possible
Old May 26, 2006 | 04:28 AM
satay-ayam's Avatar
satay-ayam
I don't think I really buy this for a FWD car. I think that for overall performance, you need weight on the drive wheels. A FWD with close to 50/50 might corner really nice, but it would likely just burn it's tires trying to accelerate out of the corner. Since weight is transferred OFF of the drive wheels when a FWD accelerates (exactly the opposite of what you'd like to happen), I think you want more static weight up front than 50% if you're going for anything more than a skidpad number.
But that's just me thinkin' again
Old May 26, 2006 | 04:53 AM
meb's Avatar
meb
...some alignment shops place the scales on the alignment machine so all can be done at one time - access is very easy.
Old May 26, 2006 | 10:05 AM
Dr Obnxs's Avatar
Dr Obnxs
Right you are....
especially with weight transfer going to the rear on acceleration...
Matt
Old May 26, 2006 | 10:07 AM
Dr Obnxs's Avatar
Dr Obnxs
That's how Custom Alignment does it...
and it does go pretty fast.... For me, I think the whole ride height adjustment, 4 wheel alignment and cornerbalance was under 2 hours... The guy had this really slick creeper that had him reclined at about 45 degress...
Was cool to watch...
Matt
Old May 26, 2006 | 10:28 AM
kapps's Avatar
kapps
At the Concours de Elegance this year, they had a few of those unlimited racers of the 70/80's. Power to weight ratio was somewhere in the 1.2:1 range
Old May 26, 2006 | 11:28 AM
J Propane's Avatar
J Propane
OK, I guess that's what happens when I type before 6:00 a.m. .... 2,200 it is. But get that thing done soon so I don't have to send you a frozen case of Canada's finest. Don't ever let your drive get away.
Old May 26, 2006 | 05:22 PM
meb's Avatar
meb
Okay, where do you live? Where is this guy?
Matt
