Suspension Weight jacking?
That's great information...Thanks Greg
I'm curious...how did they adjust your struts? With the wheels off and sitting on blocks ontop of the scale or how did they get to the adjusters in the front? And I assume you were sitting in the car?
You're not really moving any weight..
but more leveling the suspension... We're stuck with the fact that the engine is right over the front wheels, and pretty much nothing is over the rears. No ralistic amount of corner balancing will ever shift that.
BTW, those numbers look good!
Matt
Matt
Matt
Matt
BTW...did you get my PM about the TB results?
You don't really have much choice on the weight distribution.
and most of the easy lightening items don't take weight off the front...
Like removing the rear seats and going to a race battery. Closer to 50/50 would be better, but there's just no way to do it with our cars (without major surgery).
Matt
Matt
Wheels are left on. Rear coilovers can be adjusted from laying on your back. Fronts can be adjusted by just jacking the front of the car and reaching in the wheel well over the top of the tire. The coilover locking rings are above the tire.
It can take hours, but I was incredibly lucky as my car was almost 100% dialed in so it only took about one hour to fine tune it.
I think shops charge about $300 to do this job. I did it myself and I treated myself to some Mint Milanos ...
I sat in the car while 3 guys did a lot of work for a few hours.... no idea what they did....other than I saw the tools they did it with and how they affix to the coilover.......but I could not rmember how they adjusted the front
Greg, what is your estimate for weight distribution?
I'm not sure at all what will happen when I put the racecar on the scales, but I'm doing as much as I can to get some weight in the back, including myself. I might assume that it will still be about a 60-40.
sorry to HJ the thread
Supposedly the whole concept behind corner weighting is to have that car balanced diagonaly, which it looks like it nearly was ...
No amount of suspension work could shitf any usefull amount of weight to the back from the front ,( changing the center of gravity ) otherwise you would be driving in the Wheely position - front wheels in the air !
Originally Posted by MSFITOY
I'm looking forward to Greg's weight balance after his "major" surgery
Originally Posted by J Propane
Greg has a special feature built in his spreadsheet and as soon as the the total weight comes down below 2,000 lbs, a smilie authomatically appears with a beer in hand.
Come come on now Alain, .... don't take away my drive here .
But that's just me thinkin' again
Right you are....
Originally Posted by satay-ayam
I don't think I really buy this for a FWD car. I think that for overall performance, you need weight on the drive wheels. A FWD with close to 50/50 might corner really nice, but it would likely just burn it's tires trying to accelerate out of the corner. Since weight is transferred OFF of the drive wheels when a FWD accelerates (exactly the opposite of what you'd like to happen), I think you want more static weight up front than 50% if you're going for anything more than a skidpad number.
Matt
That's how Custom Alignment does it...
Originally Posted by meb
...some alignment shops place the scales on the alignment machine so all can be done at one time - access is very easy.
Was cool to watch...
Matt
Originally Posted by SpiderX
This reminds me of my friend who races "historic fomula 1" 600 whp @ 1100 lb. Is that possible
Ah ah Ahhhh .... you said below 2200....!
Okay, where do you live? Where is this guy?
and it does go pretty fast.... For me, I think the whole ride height adjustment, 4 wheel alignment and cornerbalance was under 2 hours... The guy had this really slick creeper that had him reclined at about 45 degress...
Matt
Matt
I really thought that it would be this month, but now I just hope it's by August.
