Problem A-brewin in Transmision Town
Old May 22, 2006 | 10:06 AM
biggripper's Avatar
biggripper
I think I may have a tranny problem a-brewin'. I had my car up on jack stands so I could try and fix an exhaust rattle.
While I had the car up on the stands I took it out of gear and started it. I wanted to listen for rattles and leaks. Anyway I revved the engine a couple of times and I noticed the wheels started spinning. Not in gear, mind you. In neutral. Clutch pedal out.
Let me also add that I noticed some time ago that my front wheels move freely even while in gear. Example: car up on jack stands, engine off, tranny in 1st gear, front wheels rotate freely...shouldn't there be resistance???
Let me know what you make of this.
Sean
Old May 22, 2006 | 10:30 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
This is normal. There is a relatively minute drag of the various forward gears/syncros when disengaged.
The wheels will independently move freely even when on stands while in gear due to the differential. You need to hold one wheel still while turning the other, or turn them both in the same direction.
Old May 22, 2006 | 10:52 AM
biggripper's Avatar
biggripper
Thanks for the reply, Greatbear.
I did get the same answer from James at WMS when I called.
I feel better now
Old May 22, 2006 | 11:11 AM
DownSize's Avatar
DownSize
I got beat to it, glad you got the answer you were looking for. The first time I noticed it, I was reminded of my subaru, which would move in nuetral on the road at about 15 mph, that was a whole different story
UncDeo
Nov 4, 2019 04:08 AM
CardinalsRule
Jun 11, 2016 04:34 PM
tylewis
Sep 6, 2015 01:07 PM
Manny_cooper
Sep 3, 2015 05:48 AM
Sep 2, 2015 09:05 AM
