Oil Filter Housing - Cooper & MCS
Old May 20, 2006 | 11:24 AM
TonyB's Avatar
TonyB
It is my understanding that while the engines are the same, minus some internal differences, the oil filter housing for each is also slightly different.
Can someone confirm this?
And if indeed that is the case, what exactly is different between the two?
Lastly, what is the reason for the difference?
I appreciate your thoughts, thanks!
Old May 20, 2006 | 11:32 AM
Dr Obnxs's Avatar
Dr Obnxs
Hi Tony,
there is a difference, but I can't see it! I went to REALOEM.com...
http://www.realoem.com/bmw/showparts...95&hg=11&fg=30
http://www.realoem.com/bmw/showparts...98&hg=11&fg=30
Matt
Old May 20, 2006 | 11:47 AM
TonyB's Avatar
TonyB
Yeah, I thought so... Any idea as to why there might be a difference? Thanks Matt. Where is GreatBear?
Old May 20, 2006 | 11:52 AM
Dr Obnxs's Avatar
Dr Obnxs
The S
has a oil/water heat exchanger, and the base cooper doesn't. Why the housing is different I have no clue, as the filter cartridge is the same....
Lifes little mysteries!
Matt
DrDiff's Avatar
DrDiff
Coordinator :: Northwest Indiana MINIacs
The after market places like MiniMania and others state that the same element fits both the MC and the MCS. Perhaps it is a different part number for the housing because it is on a MCS vs. MC?
Old May 20, 2006 | 11:56 AM
Motor On's Avatar
Motor On
Originally Posted by Dr Obnxs
base cooper
You mean Hod Roded Cooper right?
They look the same to me
Old May 20, 2006 | 12:12 PM
TonyB's Avatar
TonyB
Apparently inside the Cooper housing there is a black plastic center tube that can be romoved with a 19mm socket... but not so on the MCS (not removable)?
I'm heading-out for today guys, but I'll check-in later.
Really, GreatBear is awesome, and hope he sees this...
Old May 20, 2006 | 12:20 PM
DrDiff's Avatar
DrDiff
...SNIP...and the base cooper doesn't. ...SNIP...
It is true, the MC is not the base MINI, that would be the MINI ONE. MINI USA doesn't import the MINI ONE to the USA.
At the factory they consider the MC to be the factory hot rod of the MINI ONE. The MCSis considerded to be another beastie all together. The JCW MCS is the factory hot rod for the MCS.
Old May 20, 2006 | 12:59 PM
Dr Obnxs's Avatar
Dr Obnxs
Here in the US...
There is a base Cooper and a Cooper S (with or without JCW). And in Europe, there is a base Cooper as well, as the lower options go by the name of the Mini One or One D!
Matt
TREX
Nov 2, 2019 07:31 PM
Jan 4, 2019 12:51 PM
Aug 11, 2015 11:58 AM
M7Speed
Aug 6, 2015 01:48 PM
