Xenon out - must replace both?
Old May 19, 2006 | 07:32 PM
The MINITOR's Avatar
The MINITOR
One of my Xenons is out and I have read that it is recommended to replace both to color match. I am wondering if I pick up a single $99 4300 if anyone knows if it will be noticeably a different color or not, as I would rather just get one and save the money.
Old May 19, 2006 | 08:19 PM
The MINITOR
Anyone?
Old May 19, 2006 | 08:58 PM
mielnicki's Avatar
mielnicki
I would save your money, even if there were a slight color difference, after some time the new bulb should get closer to the old bulb.
Steve
Old May 19, 2006 | 09:05 PM
DownSize's Avatar
DownSize
if you did have the factory warranty, would they be covered under warranty? And I thought that the actual bulbs should outlast the car? Is it the ballast that failed? and $99 sounds pretty cheap for xenons, maybe just get two and save the one on the car incase another one blows?
Old May 19, 2006 | 09:23 PM
UKSUV's Avatar
UKSUV
Sometimes the color hue is off depending on how many hours the bulb has been in service. I would take a chance. for $99
Old May 19, 2006 | 09:39 PM
kyriian's Avatar
kyriian
mine has been intermittently turning off... especially the right one... i think i might put the 6000k ones i have lying around back on....
Old May 19, 2006 | 10:05 PM
The MINITOR
My car is no longer under warranty. The bulbs are supposed to last for around 5 years and you can see that it is the bulb, not the balast or anything.
I think it will be fine so I just ordered one Xetronicbrand bulb from xtralights.com, they were cheapest there after shipping ($109 and next day air shipping via fedex was less than $20). They were only $10 cheaper to buy the pair, so if it too noticeable I will just order another (so its only a $30 gamble). I will report back once received how the color matches etc.
Old May 22, 2006 | 05:18 AM
omascow's Avatar
omascow
The bulbs take a little while to settle into their normal color. I had one of mine replaced and it took a couple of weeks for it to match the other one again.
Old Aug 26, 2006 | 10:10 AM
cooper99's Avatar
cooper99
My driver side xenon is not coming on now...Grrrrr.... I thought xenons were supposed to last forever!? Is it most likely the xenon bulb is out or an electrical problem? BTW, my high beams still work just fine?
Old Aug 26, 2006 | 11:24 AM
pdflint's Avatar
pdflint
I had to have one xenon bulb replaced due to an encounter with a deer. I do notice a slight color difference when first turning on the lights, but no difference once they both reach full temperature. I definitely would not buy a second bulb.
Rai1gun
R60/R61 Stock Problems/Issues
Jan 11, 2016 05:52 AM
Bennyboy
Aug 18, 2015 07:28 AM
Powershift
Aug 16, 2015 05:14 PM
