Transaxle lube
Old Mar 13, 2003 | 03:27 PM
ghillie's Avatar
ghillie
Now that it is confirmed that the transaxle takes MTF94, where do I buy it?
NW Mini has it in a 25 gallon drum. They don't want to sell me any, and actually are trying to talk me out of changing mine, saying it is lifetime fill, etc. They will change it for me, but why pay the labor, and I know it's done right if I do it.
So, anyone got the inside track on where to buy this stuff?
I don't want to use anything else, i.e. Redline until the warranty is up, so I need to find a supplier.
I checked with our local Land Rover dealer as they are supposed to carry it, but they don't, they use Redline.
Thanks,
John
Old Apr 2, 2003 | 12:56 PM
MINIJC's Avatar
MINIJC
Hey ghillie:
Now that you found out that the 6-speed MCS uses MTF94, do you know what type of fluid does the 5-speed MC uses?
Thanks for any help you can provide...
Juan
Old Apr 2, 2003 | 09:08 PM
Zappa's Avatar
Zappa
They are lifetime fills. If I were to change and did not do any racing, 60,000 plus would be a consideration though. I'll find out more on the MTF94 in july when I take a gear lube class. Apparently there is something unique about that spec.. We'll see.
Old Apr 14, 2003 | 11:21 AM
MINIJC's Avatar
MINIJC
Zappa:
Do you know if the 5-spoeed MC transaxle uses also MTF94?
Is it different? If it is a different fluid, do you know what kind?
Thanks for any input...
Juan
Old Jul 31, 2005 | 03:31 PM
barnhillld's Avatar
barnhillld
Hey Zappa, any new information on the MTF94 spec?
I'm in the middle of a clutch replacement and about to stick the transmission back in. I've already picked up some Moble 1 synthetic gear oil, but figured I'd better check a bit more closely before using it.
Thanks for any information
Old Aug 2, 2005 | 01:36 PM
bradman's Avatar
bradman
See the related "%-speed gear oil post". Redline's MTL (70w-80) is an exact relapcement for the factory gear oil. Follow the link below for recommended fluids for the MC.http://www.kroon-oil.com/uk/
navybsn
R55 :: Clubman Talk (2008+)
Dec 29, 2015 12:32 PM
David.R53
Sep 13, 2015 03:44 PM
wildwestrider
Sep 4, 2015 06:25 AM
Sep 3, 2015 03:01 PM
minipopkart
Aug 13, 2015 05:22 AM
