Variations in Serpentine belt size?
Old May 14, 2006 | 07:25 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
O. K. folks! (For stock and/or 15% pulley applications) Factory parts CD lists Conti belt 6PK1388(that's 1388 mm) Have found ref. to Goodyear Gatorback 6PK1365 (that's 1365 mm) and Dayco 6PK1365. Also NAPA 25-060535 and 25-060539 (that's 53.5" and 53.9"). Why the big discrepencies? Which is/are correct? Any others?
Old Aug 5, 2013 | 03:33 PM
dhabutcher's Avatar
dhabutcher
Just did this today,
Factory size,
Gates K060547 @ 54.71 length. Dayco 5060548 @ 54.75
Goodyear 6PK1390 @ 54.70
Shorter size, -.70
Goodyear 6PK1370 @ 54.00
Shorter size, -1.0
Gates K060537 @ 53.70,
Goodyear 6PK1365 @ 53.70
Shorter size, -1.5
Car Quest K060532 @ 53.20
I have always ran the Car quest belt, with 15% Webb Pulley. never failed lots of track days and a few over revs
Old Aug 5, 2013 | 04:32 PM
ZippyNH's Avatar
ZippyNH
Stock is too big for a 15%...
It will install OK...but a tiny bit of wear...and screech....and slip
With a 15% go with a 535......
17% maybe even try a 532......
many folks are happy...less chance of slipping the smaller the belt....
Old Aug 5, 2013 | 05:03 PM
Braminator's Avatar
Braminator
Like Zippy said the 535 is perfect for a 15% pulley.
Old Aug 6, 2013 | 04:20 PM
04_Indi_Mini_S's Avatar
04_Indi_Mini_S
I used the 532 for 17% and so far so good. It was tight getting it on, but no slipping and the top of the second tensioner hole showing after break-in.
Old Apr 19, 2016 | 08:52 AM
dhabutcher's Avatar
dhabutcher
Belts sizing chart
Page 2 od PDF od Page 821 on doc. 2 mini listed belts k060539 (54 1/2) and k060547 (55 1/2)
Might help out if some needs a lil shorted belt
http://www.gates.com/oreilly/PDFs/SizeListings.pdf
elverado
Jan 18, 2022 02:51 AM
vargasgal
Sep 17, 2015 10:02 AM
lotiman
Sep 16, 2015 06:47 PM
hong
Sep 13, 2015 06:41 PM
Emnotek
Sep 11, 2015 04:16 PM
