Suspension Can stiff suspension cause CV joints to fail?
Old May 12, 2006 | 06:42 PM
waldvogelmj's Avatar
waldvogelmj
I installed the Megan Racing coilovers several weeks ago. Even at the softest setting, hitting bumps can bounce your head into the roof. My wife won't ride in the car anymore. If I hit a pothole it feels like the front of the car is going to break.
Anyways, I noticed a click, click, click this morning coming from the passenger side wheel. It's louder when I'm turning. Sounds to me like a CV joint, which is bad news because tomorrow is a track day.
Can a hard suspension be rough enough on the car to cause CV joints to fail?
Old May 12, 2006 | 06:47 PM
TooTall's Avatar
TooTall
No, but track days can.
Old May 12, 2006 | 06:48 PM
waldvogelmj
I've only done two track days with the car. Seems too early to fail from that.
Old May 12, 2006 | 07:02 PM
TooTall's Avatar
TooTall
I've had 3 or 4 go bad in a variety of cars, only one actually falling apart and leaving me stranded in a driving rainstorm. They last quite a while after you start hearing them. If the boot's still intact then it may be just one of those things.
Have you already checked to make sure there's nothing caught up in the brake caliper etc that might be making the noise?
Old May 12, 2006 | 07:03 PM
waldvogelmj
The boot looked fine. I'll just have to keep an eye and ear on it.
Old May 12, 2006 | 07:08 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Generally, a stiff suspension will not cause damage to CV joints. It's only when the geometry of the suspension gets altered excessively causing excessive operating angles that will damage the joints. In rare cases of extreme mods (or vehicle damage) you run the risk of running the axle with the inner CV joint under- or overextended, the former can cause damage to both joints.
Old May 12, 2006 | 07:30 PM
onasled's Avatar
onasled
Check your wheel bolts. I bet you have some loose ones.
Stiffer suspension will not effect the CV joints, but a car that is slammed will.
Anyway, I really bet it's loose wheel bolts.
Old May 12, 2006 | 08:02 PM
miniwrench
I have seen the brgs come apart in the joints when putting shocks on if the axle is pulled out too far
Old May 12, 2006 | 10:15 PM
kenchan's Avatar
kenchan
even at 280lbs/in, huh? that sucks for street.
Old May 13, 2006 | 04:41 AM
onasled's Avatar
onasled
This is more likely and issue in the camber plates rather then the struts.
PM meb and talk with him. he has some good time in these shocks.
Old May 13, 2006 | 01:25 PM
waldvogelmj
It wasn't the wheel bolts. I've had that problem too when the track wheels were new. The car started shaking during the first session. I came in and the wheel bolts had loosened. It happened every session that day. Someone told me that wheel bolts tend to loosen on new wheels as the paint wears off in the holes.
Came home early from the track. Not because of the noise but because of the rain. The Mini was the fastest car out there in my session when it rains. The only problem I had was with a loose front end. I didn't have the traction that other cars seemed to have in the carousel. The front end tended to slip much quicker than the rear.
Old May 13, 2006 | 05:23 PM
onasled's Avatar
onasled
did you disconect the front sway bar? if the rear is adjustable, did yoy make it a soft as it can go?
Old May 14, 2006 | 05:43 AM
meb's Avatar
meb
Huh?
280lb/in linear rate springs are not that bad for the street...335 in the rear by the way. Mine are completely civil. I personally do not think you should venture lower than 18 or 19 on the dampers. I actually prefer 10 or 11 front and rear...well, this week anyway
Old May 14, 2006 | 12:31 PM
waldvogelmj
The front is the stock sway bar and is still attached. I have the H Sport bar in the rear on the middle setting.
Old May 14, 2006 | 02:47 PM
onasled's Avatar
onasled
I probably should have been more clear in what I was responding to.
In wet track conditions the last thing you want is a stiff car. The handling problems you experienced sound like the kind of problems one would have with driving a dry track tuned car on a wet track. You should always consider softening up your suspension when it's wet by disconnecting the front bar and softening the rear if possible. You should be setting your Megans to soft dampening and light rebound. At least start from there and find the "wet track" sweet spot for your car.
Old May 14, 2006 | 07:47 PM
waldvogelmj
Thats good to know. I don't know much about how to set the stiffness of the dampers and just went by how others had them set, most likely for dry conditions.
Old Jul 17, 2006 | 12:19 AM
CynMini's Avatar
CynMini
I had a CV joint go out on the drivers side of my Stock '05 MCS.
Old Jul 17, 2006 | 05:13 AM
meb's Avatar
meb
just replaced the right side CV joint and axle...and bearing. Vibration is gone as well as the new clicking noise - which was my indication the CV joint wanted a time-out
ej
Nov 17, 2015 09:21 PM
minimofo
Sep 20, 2015 05:17 PM
RDSJCW
Sep 16, 2015 03:54 PM
hydouken
Sep 15, 2015 05:49 AM
CRC
Sep 14, 2015 07:27 AM
