Suspension Best bang for buck - suspension mods..
Old May 12, 2006 | 04:49 AM
Krut's Avatar
Krut
Ideas needed - I'm thinking of pulling the trigger on the Helix adjustable rear sway bar.
Old May 12, 2006 | 05:15 AM
SpiderX's Avatar
SpiderX
That is the first step for sure......that is one of the big 4 bang/buck mods...... pulley, sway bar, CAI, exhaust.
Old May 12, 2006 | 06:33 AM
Yucca Patrol's Avatar
Yucca Patrol
I can't believe I waited as long as I did before getting my sway bar.
Old May 12, 2006 | 06:36 AM
MGCMAN's Avatar
MGCMAN
I have the RDR/Helix swaybar. Great investment, it really helps the car maintain a more neutral (less understeer) composure in the twisties.
Old May 12, 2006 | 06:49 AM
meb's Avatar
meb
Megan adjustable coilovers and forget the bar...unless you plan to autocross...
Old May 12, 2006 | 07:09 AM
Dr Obnxs's Avatar
Dr Obnxs
And just to mix it up a bit more...
Front Camber Plates.
Rear adjustable lower control arms.
Rear bar
and if you really want to go for it... Some coil overs!
Matt
Old May 12, 2006 | 07:14 AM
UKSUV's Avatar
UKSUV
You Have A Pm!
Old May 12, 2006 | 07:19 AM
meb's Avatar
meb
Me or Doc? I don't have a pm...
Old May 12, 2006 | 07:41 AM
Dr Obnxs's Avatar
Dr Obnxs
Me neither....
To expand a bit more... If the geometry is set up right, then you tune response with bars and shock settings. And the tuning should be less sever than if the geometry is set up wrong... At least in theory!
My Mustang has the best suspension I've ever driven on a Mustang. And the springs are soft, very soft for a car of it's type. And it's that way because the geometry modification with the Griggs system are much better than the stock stuff. So it's a softer ride than I used to have, and it corners much, much better than it used to, and it puts power down much better too.
Matt
Old May 12, 2006 | 08:04 AM
meb's Avatar
meb
Precisely my point above Matt; swaybars are typically used before other more important aspects of suspension tuning are solved. But springs and dampers ideally perform fundamental suspension duty while swaybars should be used as a fine tuning mechanism. Geometery is a function of spring and damping because these fundamentally determine ride and roll rates; what geometry works for a stiff set-up may not work well for a soft set-up and vise versa.
I get plenty of rotation with my set-up and the stock bar on road courses.
Old May 12, 2006 | 03:43 PM
markldriskill's Avatar
markldriskill
Rear bar
Matt
And don't forget the xtra-wide fender flares and 10-12"wide tires in the rear and 8-10" in the front!!
vulkandino
Oct 31, 2015 08:29 PM
Tires, Wheels & Brakes
Oct 1, 2015 10:17 AM
Emnotek
Sep 29, 2015 07:37 AM
jennster
Sep 28, 2015 06:19 PM
