New Products at Coast To Coast USA!
Coast to Coast USA Performance is proud to welcome CRAVEN SPEED as one of our newest suppliers.
Here are some of the new products offered from Craven Speed:
Craven Speed FlexPod
[IMG]file:///C:/DOCUME%7E1/Larry/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]
This gauge pod setup is completely customizable. You can choose it with 2 52mm gauge cups, 2 60mm gauge cups, dual 2 52mm gauge cups or mix and match each side. There are also pivot points that allow the guages to be adjusted for better viewing.
Craven Speed 2% Crank/ Alternator pulley combo:
Available in black or red, this combo increases supercharger speed and includes a 5% alternator pulley to keep the alternator at a safe speed.
15% Billet Aluminum Supercharger Pulley:
Ultra light alternative to steel s/c pulley's for the same price! This pulley is a 2 piece tapered bore type at the ideal 15% reduction. (Also available are Craven 15,17,and 19% pulleys in S.Steel)
Craven Speed Adjustable Short Shifter:
This is truly a great shifter. Features very easy adjustment that lets you go from 0-50% reduction in seconds. Includes adapter to use stock or aftermarket *****.
There are many more Craven Speed products offered at our store and more are being added daily.
Also new to Coast to Coast is the:
Exedy Stage 3 Hyper Single Clutch with Flywheel
Built to handle 300 ft/lb at the flywheel this unit was designed to perform. This kit includes both a clutch and flywheel that were designed to work together as one. The Exedy setup weighs about 26lbs lighter than the stock setup for less rotational weight and drivetrain loss.
Come check out all our great deals and new products at Coast to Coast USA Performance!
CoasttoCoastUSA.com
CoasttoCoastUSA.com
potterstein
Sep 13, 2015 09:57 PM
F55/F56 JCW Pro Coilovers... on a Justa
MidnightF56
Sep 10, 2015 01:04 PM
OutMotoring
Sep 8, 2015 06:27 AM
