Suspension Request for data: camber plates and lowering springs
Old May 10, 2006 | 01:53 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
I've been on a thread about Ireland Engineering camber plates and it appears that more data are needed to resolve an issue. Since the issue is not specific to IE plates I ask for your data, please. Can you answer the following questions?
If you have camber plates, and if you have lowering springs (not coilovers),
1. what year is your car?
2. what negative camber can you achieve?
3. is 2. restricted by the springs hitting ridges on the inside of your shock tower?
Thanks for any responses. If your answer to 3. is yes, did you hammer the ridges down to achieve greater spring clearance at -2deg camber?
cheers,
Old May 10, 2006 | 02:44 PM
supergimp's Avatar
supergimp
1. I have a 2005 MCSa with H-Sport Springs and stock struts.
2. Currently set at -1.7deg camber with Steve's Auto Clinic camber plates (I believe made by Ireland)
3. Could go further. Don't know how much. No noticeable restriction so far by either springs or tower opening.
Old May 10, 2006 | 02:54 PM
onasled's Avatar
onasled
I had PSS9 coilovers, but they used the factory top spring perch.
'03
-3
yes
Hammered those out after about 2.5 I think.
W0TM8
Dec 19, 2019 07:50 AM
Mini7
Feb 2, 2016 07:52 PM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
