What needs to be greased?
Old May 10, 2006 | 07:45 AM
putttn's Avatar
putttn
I'm a noob to MINI and wondered if there was anything that needs to be greased. On my trucks I always found areas underneath that had zerq fittings and needed grease. Anything on the Mini Cooper that needs grease?
Old May 10, 2006 | 07:47 AM
MGCMAN's Avatar
MGCMAN
Only the palms of your MINI modding mechanic and an occasional John Law.
Old May 10, 2006 | 07:50 AM
mdsbrain's Avatar
mdsbrain
Aftermarket sway bar bits need grease occasionally.
Old May 10, 2006 | 03:29 PM
aDeLoreanGuy's Avatar
aDeLoreanGuy
Sadly most trucks these days still use decades old automotive technology. Wheel bearings, tie rod ends, and ball joints are sealed now and last a very long time without any maintenance. Thanks to synthetic oils and tighter engines, 3K-5K oil changes are also becoming a thing of the past for more and more cars!
If you have a sunroof, the tracks could probably use a greasing once every few years. Probably wouldn't hurt to do the door hinges and latches too since they are exposed to the elements.
Old May 10, 2006 | 04:04 PM
namwob's Avatar
namwob
Under drivers cowl-- wiper linkage with light oil
door hinges,hood latches& the door doesn't open too far things --30-40wt oil
hood release cable -- light oil
seat runners --multi purpose grease
doorlocks -- oil containing graphite
door weatherstrips, boot seal & any other rubber --silicone spray --(spray on rag & wipe on)
sunroof rails with--??
And my favorite--squeaky windows--will need to remove door panels to grease (see squeaky window fix for directions)
That should keep you buisy for awhile!
Old May 10, 2006 | 04:05 PM
namwob's Avatar
namwob
Oh, grease-- window rails & seat rails
Old May 10, 2006 | 04:47 PM
Crashton's Avatar
Crashton
I don't believe you'll find a single zerk on a MINI. For that matter not many other cars have them either.
OutMotoring
Mar 3, 2017 06:29 AM
gknorr
Dec 26, 2016 09:38 AM
theblackfalcon
Oct 19, 2015 05:22 AM
Sep 14, 2015 12:48 PM
Sep 10, 2015 10:52 AM
