Overheating at idle. All fuses are OKAY. Ideas?
Old May 7, 2006 | 07:39 PM
markldriskill's Avatar
markldriskill
About 35000 miles on my 04 MCS. I had no overheating problems of any sort until just a couple of weeks ago. Now my fan runs a lot more, and for the first time ever, the car overheats while idling only, never as long as I'm moving. I JUST had it in for service not three weeks before this started happening. All fuses are okay, so it is not the infamous pwr strng fan.
Ideas?
Old May 7, 2006 | 07:44 PM
kenchan's Avatar
kenchan
did you check coolant level?
Old May 7, 2006 | 08:44 PM
XAlfa's Avatar
XAlfa
I would pull out the thermostat and test it. That's one easy variable to eliminate.
Old May 7, 2006 | 08:47 PM
Motor On's Avatar
Motor On
Thats my bet, these cars burn/leak coolant at a previously unbelievable rate.
Old May 7, 2006 | 09:02 PM
UKSUV's Avatar
UKSUV
I'll put my money on a bad thermostat.
Old May 7, 2006 | 10:00 PM
kenchan's Avatar
kenchan
^^ that's where im going next if the coolant level is ok.
Old May 7, 2006 | 10:03 PM
namwob's Avatar
namwob
Try bleeding the 2 air bleed screws
Old May 7, 2006 | 10:06 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
It is most likely the power steering fan, which has blown your 5 amp fuse under the bonnet. On earlier cars, the fan for the rad is the on the same fuse as the power steering fan.
Look under the fuse cover in the engine compartment, and check the 5 amp fuse. If it is blown, replace it and check your power steering fan for stickiness.
Hope that helps!
Randy
Old May 8, 2006 | 06:34 AM
markldriskill
Thanks, all. I will check that stuff in sequence and get back.
Old May 8, 2006 | 07:45 AM
XAlfa's Avatar
XAlfa
Sounds like it's not the PS fan as all your fuses are ok.
T-Stat Check How To: http://www.focushacks.com/printable.php?modid=60
Filmy
15
Jun 6, 2023 06:27 AM
eliseo1981
Sep 30, 2015 01:53 PM
Camaro108
Sep 9, 2015 04:37 PM
Camaro108
Sep 9, 2015 01:56 PM
