understanding offsets........
Old Apr 26, 2006 | 09:25 AM
tpetro33's Avatar
tpetro33
Hi gang,
Quick offset question....making sure I am understanding it right.....If you're comparing 2 wheels, say both identical, but one is offset 37 and one is offset 44. The 2nd wheel is 7 mm further away from the centerline of the wheel---towards the STREET side. So that would move the whole wheel IN towards the wheel well????
Is that correct??????
Thanks!!
Old Apr 26, 2006 | 09:30 AM
HC0624's Avatar
HC0624
Originally Posted by tpetro33
Hi gang,
Thanks!!
You know what, I had the same problem figuring out the offset before. Try to use this offset calculator..... hope this can answer your question. gd luck!
http://www.1010tires.com/WheelOffsetCalculator.asp
Old Apr 26, 2006 | 10:31 AM
kapps's Avatar
kapps
The lower the offset, the further it will be pushed out. High offsets will push the wheel inward toward the brakes.
example: the stock S Lites are a +48 offset while an aftermarket wheel is +40. The aftermarket wheel will be 8mm further out than the S Lites.
A spacer of 8mm would make the S Lite like a +40 offset wheel.
Old Apr 26, 2006 | 10:32 AM
meb's Avatar
meb
The higher the NUMERIC offset, the closer the tire's center will be to the car's centerline. My 38mm offset BBS wheels stick out about a 1/4" +/- farther than my 45mm offset Team Dynamics.
Old Apr 26, 2006 | 01:26 PM
o-ron's Avatar
o-ron
keeping the same wheel size/dimensions (17x7 / 205-40-17) and stock suspension, what's the minimum offset that you can put on a wheel before it starts hanging past the wheel well (and possibly rubbing?)
Old Apr 26, 2006 | 01:35 PM
meb's Avatar
meb
13mm = 1". So, based upon my 38mm BBS wheels...31-32mm gets you pretty close. I wouldn't suggest it for a number of reasons...but reason is sometimes missing from some of the things we do...
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
GAT
Oct 4, 2015 07:27 PM
bradstyle
Oct 1, 2015 11:15 AM
BushOner
Sep 29, 2015 08:42 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
