Suspension Recommended first suspension mods...
Old Apr 23, 2006 | 01:34 PM
dmeyer's Avatar
dmeyer
Hey all...what are people generally doing first in the way of suspension mods? I have a 06 JCW on the way that I'd like to get to work on. I'd like to lower the car a little but not having it set on the ground. This will be used primarily for street.
What's the best bang for the buck?
Self installable?
Old Apr 23, 2006 | 01:47 PM
Mini Pete's Avatar
Mini Pete
Try a rear sway bar. I have the H Sport competition rear sway set on the medium setting and it makes the car handle really flat and does not affect the ride. Really a great mod and not too expensive. About $250 installed.
Old Apr 23, 2006 | 02:09 PM
FlynHawaiian's Avatar
FlynHawaiian
H-sport rear comp bar, middle setting. Install the H-sport springs. Makes the car handle just like it should. I would recommend the rear camber adjustments, uppers and lowers. And the M7 USS.
Old Apr 24, 2006 | 07:40 AM
OldRick's Avatar
OldRick
Rear sway bar. Don't lower the car unless you enjoy the sound of plastic scraping when you enter driveways.
Old Apr 24, 2006 | 07:51 AM
BrianGoldbloom's Avatar
BrianGoldbloom
You're already paying for the upgraded JCW suspension, which is pretty nice for street use. Try it for awhile that way before deciding the go further. Get a larger rear sway bar, and set it on the softest setting first before going stiffer. Get some light weight wheels and good non-runflat tires right away. They will make a huge difference in how the car handles - and rides.
Old Apr 24, 2006 | 07:57 AM
dmeyer's Avatar
dmeyer
JCW Suspension? Not on the base level JCW kit.
Old Apr 24, 2006 | 08:02 AM
CarFreak!'s Avatar
CarFreak!
Off topic:
But I would really like to see some pic's of your car!
Astro Black MCS JWC must be fantastic!
Old Apr 24, 2006 | 08:11 AM
BrianGoldbloom
Hmm, perhaps I am mistaken. I thought the suspension was included with factory-installed JCW package. No?? Been making mistakes since 1950.
Nevertheless, I still stand by my recommendations for first mods.
Old Apr 24, 2006 | 11:13 AM
coopercrazy's Avatar
coopercrazy
Rear Sway!!! and of course, non RFs. And ditch the Slites if you got em.
Old Apr 24, 2006 | 11:18 AM
HC0624's Avatar
HC0624
Sway bar is a good choice. I would put some lowering springs on it first for some appearance, and it helps to improve handling as well....
Old Apr 28, 2006 | 07:17 PM
RAW_MCS's Avatar
RAW_MCS
Though not the best bang for the buck, i had the JCW Suspension installed...
I love it, lowered the car 1/2", really smooth handling!! great for street use and no rubbing! plus the snazzy red springs (bonus).
Now i'm lookin into the Sway Bar & M7 USS...
MotorOn .
Old May 1, 2006 | 01:41 PM
justaguyinvegas's Avatar
justaguyinvegas
Rear sway bar is the best bang for your buck. It reduces some of the understeer and really improves the cornering feel.
Old May 1, 2006 | 01:51 PM
Dr Obnxs's Avatar
Dr Obnxs
I like front camber plates.
A bit more negative camber up front helps with the handling as well. I have RDRs, and Jimz68 just put on the Ireland Engineering fixed ones, and was raving about the improvment as well. If you like to corner hard, this will extend the life of the front tires. I was really grinding off the outer edge on the front with the stock set up.
Rear bar works wonders as well.
Matt
Old May 3, 2006 | 10:41 PM
ICEMAN's Avatar
ICEMAN
Congrats on the car, I have an 06 JCW MCS as well. I agree with everybody that says to get an adjustable rear sway bar, it will definitely sharpen the handling. My first suspension upgrade is a set of Helix camber plates(no cutting or drilling) because you can't get negative camber up front without them and without negative camber, a MINI used for spirited driving will chew up the outside of the front tires-the extra juice of the JCW will speed this process up considerably. My next purchase will be an H-sport adjustable rear sway bar, then a strut tower brace. Once your crappy runflats are gone, get some proper tires like the Falken Azeni, the difference will blow your mind.
Old May 4, 2006 | 09:11 AM
04SDmini's Avatar
04SDmini
Definitely a rear sway bar (I have the H sport set at medium like so many others here). Personally I think the next best thing is a good set of tires and some fix-a-flat (just in case) Save the rest of your money until you get a feel for how the car drives!
Old May 4, 2006 | 10:12 AM
MGCMAN's Avatar
MGCMAN
22mm rear sway bar, set to the middle position. I have an RDR/Helix bar, but there are many fine alternatives on the market.
ej
Nov 17, 2015 09:21 PM
Moya45
Sep 11, 2015 02:21 PM
Tires, Wheels & Brakes
Sep 10, 2015 03:10 PM
Suspension Products
Sep 10, 2015 11:46 AM
mikeson
Sep 6, 2015 06:21 AM
