Pulling during shifting
Old Apr 21, 2006 | 05:45 AM
tx-jbird's Avatar
tx-jbird
I have noticed my MCS has stated pulling to the left slightly when accelerating hard and shifting. When down shifting, it pulls the right. Has anyone else had this problem? If so what is causing it.
Old Apr 21, 2006 | 06:41 AM
lcubed's Avatar
lcubed
i'd start w/ the cheap things.
check your tire pressure, then tire condition, then alignment.
Old Apr 21, 2006 | 06:42 AM
Bigcoyote's Avatar
Bigcoyote
My 04 MCS does this every once in a while - I attribute it to the FWD ( torque steer ). I also have the run flat tires that grab the ruts in the road -- so it could be either one:impatient
Old Apr 21, 2006 | 07:09 AM
tx-jbird's Avatar
tx-jbird
I noticed it after hitting some road debris. I have since replaced the front left wheel and tire, repaired the left rear rim, rotated and balanced all 4 wheels, and had a 4 wheel alignment. My dealer did a visual inspection of the suspension and did not notice any damage. I guess my concern is whether the differential could have been damaged or not.
Old Apr 21, 2006 | 10:16 AM
lcubed's Avatar
lcubed
what size wheels and tires are you running??
did you check the tire wear and pressure yet??
my local garage is notorious for pumping up the tires to
the limit marked on the sidewall.
Old Apr 21, 2006 | 12:15 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Have the front suspension bushings as well as the upper strut mount checked. Both of these areas have rubber that can crack and become 'sloppy' under stress (acceleration and braking). Also check for play or looseness in the steering rack and it's mountings.
A pull under accel and braking after having damage is often caused by a still bent part remaining in use but having the alignment brought back by an adjustment. If a lot of adjustment was needed to bring things back in spec compared with the opposite side, the geometry of the suspension/steering becomes asymmetrical and will suffer as a result.
Old Apr 21, 2006 | 07:22 PM
tx-jbird's Avatar
tx-jbird
Thanks, I will do that.
Old Aug 21, 2006 | 05:53 AM
m&mini's Avatar
m&mini
Pulling During Shifting
I had the same problem and was told it was normal, but I insisted that it was not the way it drove when i bought the car. I was lucky that a factory rep was at the dealership that day and he found a loose balljoint. The problem went away immediatly. I would have your dealership check that as well.
Old Aug 21, 2006 | 06:45 AM
JohnnyOhhh's Avatar
JohnnyOhhh
well, if it was your differential, it would make a good excuse to get a quaife...
patsum
26
May 29, 2021 06:29 PM
donniedarko
Oct 21, 2015 01:15 PM
Sc00terbum
Sep 11, 2015 07:17 AM
nayr924
Sep 8, 2015 02:41 PM
SneedSpeed
Sep 2, 2015 05:34 AM
