Run flats
Old Mar 8, 2003 | 02:30 PM
dbMINI's Avatar
dbMINI
I got a mini cooper S with the run flat tires...one tire - after a month - continues to go to 15 lbs psi once a week...am i stuck having to buy a new tire?any other ideas? my dealer - is useless to me.
my email is hoyagu@yahoo.com - pls send email if you can.
thx
Old Mar 9, 2003 | 06:40 PM
Ryephile's Avatar
Ryephile
a slow leak, it sounds like. Have the tire re-mounted, and if it continues, buy a new tire from Dan at Tire Rack (dealership is overpriced)
Good luck
Old Mar 14, 2003 | 08:32 AM
dbMINI's Avatar
dbMINI
IS TIRE RACK in the Wash, DC area? Anyone know a good place to take a tire to for remouting? I live in Arlington, Virginia. My dealer is less than helpful to say the least.
>>Good luck
Old Mar 14, 2003 | 12:16 PM
retroom's Avatar
retroom
Check your valve stem. The mechanism inside the stem might be loose, it can be tightened with the right tool.
retroom
Old Mar 14, 2003 | 12:35 PM
dpilgrim's Avatar
dpilgrim
Road King :: 130,000 miles and counting
I have the Dunlop run flats. I got a nail in one and had it plugged. That held up for about 2 months. I then went in to have it patched on the inside at my local tire shop. After taking the tire off they found I had a cut on the inside about 4 inches long which wasn't noticable from the outside. Needless to say after the nail I have no recourse. Maybe have a look on the inside. If the valve stem doesn't check out.
Old Mar 14, 2003 | 12:37 PM
DrkSlvrS's Avatar
DrkSlvrS
dbMINI - If it turns out you have a leak you can always have it repaired (as long as it is in the tread area). A few months after I got my car I had a flat from a screw in my right rear tire. Took it to a tire shop and they repaired it for $7.00. I'm still running on that tire (21,500 + miles) without any problems.
Old Mar 17, 2003 | 08:05 AM
Alex@tirerack's Avatar
Alex@tirerack
Unfortunatly we're not in the DC area, but you can use THIS to help you locate an installer
Dan
>>>>Good luck
khumpert
Nov 30, 2015 11:48 AM
Dieseldoctor
R55 :: Clubman Talk (2008+)
12
Sep 10, 2015 04:48 PM
ltjpunk7
Sep 6, 2015 07:32 AM
TJANK
Aug 24, 2015 06:11 PM
jziran
Aug 24, 2015 04:50 PM
