205/40/17
Old Apr 12, 2006 | 06:17 PM
chefdog96's Avatar
chefdog96
205/40/17
is this too much of a low profile tire? if anyone is running this size please share your opinions about ride noise, comfort, etc and which tire you are running. i don't plan on doing any track time just like the look and need a good all around street tire. thanks everyone
Old Apr 12, 2006 | 07:06 PM
thulchatt's Avatar
thulchatt
Not 205, but 215/40/17 and it is fine. The ride is a little hard but otherwise great.
Old Apr 13, 2006 | 07:45 AM
ScuderiaMini's Avatar
ScuderiaMini
used 205/45/17, 215/45/17 and 215/40/17, i loved 215/40/17s, a little harsher, but not a lot, and looks nice with a clean drop
Old Apr 13, 2006 | 07:54 AM
lexlow's Avatar
lexlow
215/40/17 Falken Ziex Ze 512 perfect for street with a thread of 360!
Here an example of other choises available?
http://edgeracing.com/tires/2154017/
Old Apr 13, 2006 | 08:21 AM
rl48mini's Avatar
rl48mini
I don't know what tire you're thinking of running but I don't think the 205/40 will have the load rating needed by our MINI's (might work okay as an autocross tire but maybe not so well on the street)
Old Apr 13, 2006 | 05:24 PM
chefdog96's Avatar
chefdog96
if anyone has pics of 215/40/17 tires i would greatly appreciate it. thanks for the opinions everyone. keep'em comin
Old Apr 13, 2006 | 06:29 PM
kenchan's Avatar
kenchan
205/40/17's are too small (since you wanted comments comin)
Old Apr 14, 2006 | 05:22 AM
NiteSpeed's Avatar
NiteSpeed
May be a bit off topic here, but I have some 17" rims with 7x17-4x100-ET38, with 205/40 GoodYear GSD3-F1 Will these fit on the mini?? The rims I mean..
Old Apr 14, 2006 | 07:52 AM
Passat774's Avatar
Passat774
rims yes they will fit
Old Apr 14, 2006 | 08:19 AM
NiteSpeed's Avatar
NiteSpeed
KK, thx.. thay sounds great.. Cuz they will look SupErb on my mini...
Old Apr 14, 2006 | 09:03 AM
meb's Avatar
meb
205/40/17 Toyo RA1s for the track. The load rating is a hair under stock for 16" run flats for example, but this is a light car. I was told by accomplished racers not to worry. I've already had one track day one these and I drove about 300 miles on them before I went to the track.
The gearing advantage is somewhat noticable midrange to about 125mph.
I'm not sure I would use this size as a daily driver...my concern is for rim protection. But the RA1s on the street were quite nice; grippy, edgy, and not really any less comfortable than the 205/45s, dunno why.
Onasled has lots of miles on this size at the track.
Weight and tire circumference made the choice very clear for me.
Old Apr 14, 2006 | 10:50 AM
stevecars60's Avatar
stevecars60
I'll second that... Great tire choice, I'm realy liking mine, the more you drive them the better they get....
Old Apr 14, 2006 | 10:59 AM
Motor On's Avatar
Motor On
215/40/17 here, I run about 4 PSI under cold, they warm up to the max cold setting quickly but 44 psi cold was worse than runflats for ride quality, but all has been much quieter since the switch. These are Goodyear Egale HPs
Old Apr 14, 2006 | 11:08 AM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
Old set of tires toyo proxes 205/40/17 no suspension mods
Rides a little rougher and gotta be xtra careful about what you run over.
now back to 205/45/17
a little bit softer and handles just as well. Then I put H&R springs and a 22mm sway and it got rougher (in a good way). I've got dark wheels so the side wall height doesn't bother me.
ruben blades
Dec 2, 2015 03:43 PM
tl915
Tires, Wheels, & Brakes
Mar 14, 2007 06:35 PM
gtbuzzmini
Feb 5, 2007 11:19 AM
chefdog96
Jul 20, 2005 06:52 AM
