Navigation & Audio IceLink + Stock SIRIUS?
Old Mar 30, 2006 | 06:35 AM
scatpack's Avatar
scatpack
Will it work?
The icelink is hooked up using the factory CD Changer wiring. Does the factory Sirius box use the same input OR is there a different connection in the rear hatch for the Sirius box?
Old Mar 30, 2006 | 10:01 AM
Edge's Avatar
Edge
AdMINIstrator
Originally Posted by scatpack
Will it work?
The OEM SIRIUS receiver has a passthrough connection, which allows you to still connect the CD changer (or a CD changer replacement such as the IceLink). The one limitation that still applies regardless of whether you have OEM SIRIUS or not... you can't have the CD changer and the IceLink, because they are both "ends" of the cable.
In short, yes it will work. You may need to buy an extra "extension" cable or two from MINI - the SIRIUS install docs list the part numbers. One is only needed if you have the H/K, to move the SIRIUS receiver to the other side. The other cable is if you want to use the CD changer (or IceLink, by extension).
Colt45Magnus
Aug 27, 2024 05:03 AM
USA-RET
Nov 9, 2015 07:27 PM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
