Cooper (non S) Modifications specific to the MINI Cooper (R50).
Midlands Torque Limit
Old Mar 17, 2006 | 08:39 PM
autopia's Avatar
autopia
I know I've run across information regarding this before, but I can't seem to find it again. What is the lb-ft torque limit on the Midlands transmission?
Old Mar 17, 2006 | 09:10 PM
UKSUV's Avatar
UKSUV
About 10FT LBS. That's about it.
Old Mar 17, 2006 | 09:15 PM
autopia's Avatar
autopia
No wonder mine got replaced at 22691mi! Seriously though, I often see comments about how the Midlands really shouldn't take nitrous or turbo charging. But how much can it handle?
Old Sep 11, 2006 | 01:00 PM
Ranzo's Avatar
Ranzo
What exactly is weak in the Midlands? If the tranny breaks which part goes first?
Old Sep 11, 2006 | 02:36 PM
justintime's Avatar
justintime
the syncs? just a guess... possibly everything falls apart at once like a drama movie.
I have a question reguarding this as well..
whats the difference bewteen the midlands and the trans. they put in the 06?
thanks ahead =]
Old Sep 11, 2006 | 03:13 PM
Ranzo's Avatar
Ranzo
I just got an email back from HPA about they're Mini Cooper "Gokart" Since the car was pro built for racing applications I thought, "Hey they must have done something do strengthen the gearbox" to my suprise this is what he had to say...
Randy,
Thank you for your inquiry. The Mini Cooper HPA constructed was built to be a fun weekend track vehicle and included such custom touches as carbon fiber door inserts. Of course to be competent on the track, the car used KW Competition suspension, light weight wheels and the independent throttle body system you have attached. It was a one off project for HPA, but I could look to source you the ITBs if you were interested. I suspect you will be looking at approximately $3000usd for the system.
As for the transmission, I believe it used the original as delivered.
Please feel free to give me a call for more information.
Kind regards,
Jared Powell-Williams
Lead Sales Executive
HPA Motorsports Inc.
WTF?!?! The car is an 03 so it's got a Midlands in it... so a pro built race car with a weak stock tranny?
Old Sep 11, 2006 | 04:41 PM
autopia's Avatar
autopia
It just seem you continuously hear how adding a turbo or nitros is n/g on the midlands tranny. I was just wondering what the thing could handle without putting too much stress on it, particularly as far as a daily driver.
Old Sep 11, 2006 | 08:49 PM
justintime's Avatar
justintime
I personally dont see adding nitrous as being much of a daily driven car application.
and the hpa guy didnt say he modified the car much besides the suspension and throttle body... so mabye there just wasnt a need for a new tranny?
Old Sep 11, 2006 | 11:40 PM
goin440's Avatar
goin440
I don't know that the tranny itself is weak. But if the outdrive boots spring a leak, you could be in need of a new tranny if you don't catch in time.
I'll put it this way, I have yet to read of a failed tranny that didn't leak through one of the outdrive boots.
Old Sep 12, 2006 | 07:41 AM
Ranzo's Avatar
Ranzo
Is that related to the seals? Usually happens in cold weather and the tranny fluid leaking out?
Are people confusing this problem with the transmission being fragile when power is added?
Old Sep 12, 2006 | 09:47 AM
goin440's Avatar
goin440
Yes, its the seals(boots) on the outdrives that are faulty.
IMHO, yes. But stock trannys for any car may fail when power is added. Whether or not increased power will shorten seal life...? For the Cooper, unless you go turbo, I believe the tranny would hold.
Old Sep 12, 2006 | 10:49 AM
scobib's Avatar
scobib
Locally, we've had club members Midlands fail when they were completely stock and when they were slightly modded. One guy's on his second tranny and his service house located an output bearing with a metal race (I guess the stock one's all plastic), and ever since he put that in it's been more reliable for him... They installed it when they were in there putting in a lightweight flywheel and aftermarket clutch (he's WAY over warranty, being a 2002 with some 90K+ miles).
Old Sep 12, 2006 | 11:13 AM
Ranzo's Avatar
Ranzo
ahhh... i get it now... maybe we need to start a thread to get the myth straighten out!
Old Sep 12, 2006 | 11:20 AM
Ranzo's Avatar
Ranzo
THANK YOU VERY MUCH!!! Great information. My clutch and flywheel is toasted at the moment... I've been trying to find information on how to strengthen the tranny. where would I find such a part? Or should it come with the clutch kit? Thanks again!
Randy
Old Sep 12, 2006 | 01:27 PM
Ranzo's Avatar
Ranzo
BMW MINI COOPER TRANSMISSION DIFFERENTIAL BEARING
When installing a Quaiffe or other Limited Slip Differential, we highly recommend replacing the carrier bearings. Sold individually; two required.
Something like this?!?!
Old Sep 12, 2006 | 02:32 PM
scobib's Avatar
scobib
That's the carrier bearing for the diff... this is actually the output shaft bearing. I saw ONE on eBay some time back that was being sold by a tranny shop. It was in OEM packaging, so I'd wager it's an OEM part?
Old Sep 12, 2006 | 02:56 PM
Ranzo's Avatar
Ranzo
So cost effective to fix the fault... but I can't find it anywhere!!!
Thanks anyways!
Old Sep 12, 2006 | 08:23 PM
scobib's Avatar
scobib
I'll see if I can get more info...
Old Sep 13, 2006 | 12:58 AM
goin440's Avatar
goin440
Locally, we've had club members Midlands fail....
I believe the output bearing is part of seal. They both dump together like. Cold weather (in theory) was cracking the plastic ones and causing the seal to leak.
We're talking about the same thing but you said it better
Old Sep 13, 2006 | 08:19 AM
Ranzo's Avatar
Ranzo
Thank you so much... if not then maybe I can get the part fabricated by a machinist?
Old Sep 15, 2006 | 07:26 AM
Ranzo's Avatar
Ranzo
Any info yet?
Thanks!
Randy
Old Sep 15, 2006 | 11:46 AM
scobib's Avatar
scobib
Nope - guy is out of town right now. As soon as he gets back, he'll gimme a shout...
Old Sep 18, 2006 | 08:49 AM
Ranzo's Avatar
Ranzo
Found this post... maybe the same guy?
https://www.northamericanmotoring.co...6&postcount=42
Car is going in the shop on Wednesday. I'll ask them about it and see if they can source out the part or maybe find a machinist.
Old Sep 18, 2006 | 08:58 AM
scobib's Avatar
scobib
That's the very same guy, yup...
I just remembered that Rick Jordan at 5th Gear Motorsports (or his son Ricky) might be able to get the info for you, since they did the work... Phone number is: 972-317-4005.
Old Sep 18, 2006 | 09:15 AM
Ranzo's Avatar
Ranzo
SWEET!!!!! Thank you very much! Okay gave him a call and he said he just took out the stock bearings and went to a local bearing shop and matched it up. Hopefully this will make the weak midlands STRONG!
