Suspension JCW Suspension rear bump stops
Old Mar 17, 2006 | 08:53 AM
Silver JCW Rocket's Avatar
Silver JCW Rocket
I have a question, I just installed JCW suspension on the wifes 06 car, ever thing is great, but I read in the instrustions to mod (notch) the rear inner flange above the upper control arm and install a bump stop on top of the upper control arm. I understand that the mod (notch) to the rear inner flange is not necessary on 05-06 cars (all ready notched from factory), but are the bump stop also not necessary to be installed on 05-06 cars?, I think they are also not installed because there is no way to mount them to the upper control arm on a 06, no holes on the top of the control arm for mounting?.
So any one out there with a 06 with JCW suspension installed please take a look to see if the stops are mounted.
TIA
Old Mar 17, 2006 | 10:27 AM
Mike MCS's Avatar
Mike MCS
I don't think it's a seperate hole? But the bumpstop should be fitted?
Old Mar 17, 2006 | 03:17 PM
Logitex's Avatar
Logitex
have any pics of this notch where the bumpstops are suppose to go?
Old Mar 19, 2006 | 12:05 PM
ScuderiaMini's Avatar
ScuderiaMini
http://motoringfile.com/howto/JCW_Su...structions.pdf
i hope this helps, does the kit include bump stops, because the installation pdf does.
Old Mar 20, 2006 | 11:53 AM
Silver JCW Rocket
The kit came with the bump stops, but there is no way they will attach to a 06' upper control arm, there must be a change to the current upper control are from previous years?.
Old Sep 9, 2006 | 11:00 AM
bobdobbs's Avatar
bobdobbs
I concur. No way to put the bump stops on an '06. Into the trash they go...
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
silence2-38554
Nov 12, 2015 09:39 AM
Minibeagle
Aug 13, 2015 10:00 AM
nomar116
Aug 10, 2015 11:24 PM
